It is currently Thu Jun 26, 2025 10:55 am
Post new topic Reply to topic  [ 45 posts ]  Go to page 1, 2, 3  Next
 Post subject: bonnet scoops
PostPosted: Fri Apr 20, 2007 8:01 pm
hey guys
wanting to put a scoop on my clubby
any suggestions??
PostPosted: Fri Apr 20, 2007 8:06 pm
ERA Turbocharged minis had them facing backwards as apparently the issue isn't getting the air into the bonnet, but getting the now hotter air out of the engine bay.
Though scoops seem to be more about aesthetics than function, that may have been their idea of cool.
Flutes for the old school look.
I saw a clubby the other day with an Evo 7 scoop setup. Interesting. 8)
PostPosted: Fri Apr 20, 2007 8:09 pm
Does depend on what your running..Turbo...Webber Box....or Normally Asperated or Hydro?
PostPosted: Fri Apr 20, 2007 8:11 pm
Hydro??? :? *raises one eyebrow*
PostPosted: Fri Apr 20, 2007 8:27 pm
Bonnet scoops are a good way to remove excess oil from the engine bay and spreading it on the windscreen.
The front of the car is blunt (Clubbies are even blunter) a lot of air is forced into the grill and this air finds its own way out. A lot goes out through the radiator and a lot passes under the car.
If you open a hole in the bonnet air will not be forced into the engine bay but it will let air out.
Because of the shape of the car the top of the bonnet (except for the front bit) will be in a low pressure area.
PostPosted: Fri Apr 20, 2007 8:38 pm
RICE......
PostPosted: Fri Apr 20, 2007 8:59 pm
A very modest arrow shaped scoop with a separator in the middle looks mad on clubbies, I can't remember where I saw that. On a roundie an Austin or Shelby style scoop would look good, but I think you have to keep it real modest and classy to pull it off.
I bought a book a couple of weeks a go called "The metal fabricators hand book" which details making a scoop (and other various body mods) by hand from sheet metal, might be worth a read.
PostPosted: Fri Apr 20, 2007 9:17 pm
keep it orinal mate, unless you got a turbo or something allready in there
PostPosted: Fri Apr 20, 2007 9:24 pm
can't help but to show it off again personally i like it but some don't :D(subaru forester)
Darren
00 triton d/cab
55 chev(oversize moneybox)
1963 850 (roundie)
77 clubby
95 zxr 750 + toys!!
PostPosted: Fri Apr 20, 2007 9:31 pm
resident alien
resident alien
Mine... they came with the car :)
PostPosted: Fri Apr 20, 2007 11:11 pm
my bonnet scoop, wrx. $80 from www.ssv.com.au
PostPosted: Fri Apr 20, 2007 11:25 pm
Wrong style of car to be riceing up guys...
I really like the scoop off the gt clubman "DUS 13S"
sorry couldnt get a pic on here
its not to over the top gives it a mean look
and defininatley wouldnt turn it into a ricer
PostPosted: Fri Apr 20, 2007 11:53 pm
Who said anything about rice?
How is what you have done to your car not rice?
If I put a bonnet scoop on a Mustang is that rice?
If I put a flare kit on a Torana is that rice?
If I put a turbo on a Mini is that rice?
Is that different to putting a turbo on a big block Chev?
What about a body kit on a Lancer EVO? Rice?
Turbo on a Suzuki Swift? Rice?
Suzuki Swift motor in a Mini?
Gen 4 LS2 in a 36 ford coupe?
What are you trying to say?
If I hand made some flutes and put them in my guards, and it was done tastefully, would that be rice? or would it be a neat custom job?
If you didn't like it, move on, go find something you do.
I don't believe you can rice a mini. Not without putting in a lot of effort fitting kits, modernizing it with lights etc... you would have to have neons, modern turbo dohc motor, airbrushed paint...
I think I could appreciate that...
