It is currently Tue Jun 24, 2025 8:02 pm
 Post subject: Cooper S Brakes
PostPosted: Fri Apr 20, 2007 7:15 pm
Hi,
What is the minimum thickness allowed on the disc's on Cooper S front brakes?
That's the 7.5 inch ones.
Mine are at about 6mm.
PostPosted: Fri Apr 20, 2007 7:26 pm
I thought it was about 9mm. Anyone else?
PostPosted: Fri Apr 20, 2007 7:35 pm
8mm (5/16") unless marked otherwise. They are 3/8" thick when new.
Some newer ones are marked 8.5 limit.
PostPosted: Fri Apr 20, 2007 7:42 pm
My old Scientic Publications manual has the following :
from the diagram
2.292 - 2.078 = 0.214
Using 1 inch = 25.4 mm
0.214 = 5.4356 mm
So if "about 6mm" I'd be looking to replace...
PostPosted: Fri Apr 20, 2007 7:54 pm
That looks like a Cooper 997/998 rotor, they were only 6.35m (1/4") thick when NEW.
I would never run S ones below 8.0mm machining, or 7mm wear limit.
PostPosted: Fri Apr 20, 2007 8:05 pm
Hey Doc,
I've never seen anyone use a brake rotor to destruction. Though it sounds like you have, what's the results of using them below the thickness? I always assumed they wouldtend to distort a little to easily by then.
PostPosted: Fri Apr 20, 2007 8:12 pm
Checked the book and is dealing with both Cooper & S - and makes no distinction between them....and no identification in diagrams ..... so very possibly true :oops:
None of the other "books of words" give any specs....
Remember seeing someone at Minifest 91 trying to sell some old 7" rotors that were so thin you could almost see through them.... he refused not sell them - so someone bought them in the interests of safety to stop some unsuspecting person using them...
PostPosted: Fri Apr 20, 2007 8:30 pm
Mick wrote:
Hey Doc,
One problem with indersize rotors is the pads can fall out on da road... :lol:
As my mate with the Fiat 125 found out.
Other problem is they fade sooner as there is less thermal mass.
The general rule with most small rotors I've found is the machining limit is around 1.5mm less than new thickness.
Obviously you can then wear a bit off them with the pads- but once they need it done again they are stuffed. It's illegal for brake shops to machine them again if worn below the limit.
Last edited by drmini in aust on Fri Apr 20, 2007 8:33 pm, edited 1 time in total.
PostPosted: Fri Apr 20, 2007 8:33 pm
Oh so only the obvious stuff like you mentioned, I thought maybe they failed in some other way but I couldn't guess what.....
PostPosted: Fri Apr 20, 2007 9:38 pm
Slow-Po
On my old ford escort, I used to get brake fade fairly easily. The discs where the only thing that hadn't been replaced, I ditched them and the extra meat in the new rotors made a big difference.
PostPosted: Sat Apr 21, 2007 12:59 am
I have rotors that are on the 8mm limit sitting on my shelf. They are mighty weak looking compared to the new rotors I have on my car.
Rotors are relatively cheap, why would you risk it?
PostPosted: Sat Apr 21, 2007 10:21 am
Thanks for the info guys.
I will fit some new rotors.
Are standard rotors all the same,
Or are there some inferior ones out there?
PostPosted: Sat Apr 21, 2007 11:54 am
I've found even the RDA ones (made in China) are OK, mine stop fine with EBC Greenstuff pads. For road use any brand is fine.
If you are going racing it might pay to pay more $$ and buy crossdrilled or slotted,.
PostPosted: Mon Apr 23, 2007 10:55 am
OK, stupid question: why are they still on your shelf then? Why not chuck em?
PostPosted: Mon Apr 23, 2007 11:16 am
Nobody likes a hoarder :wink: :lol:
