It is currently Tue Jul 08, 2025 3:10 am
Post new topic Reply to topic  [ 41 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Apr 05, 2007 9:06 pm
wisey wrote:
With 1100S valves and kent 276 and reasonable compression on a +20 998 I have had to pocket the bores a little for the zoorst valves. This combo worked quite well for me on a roadie, however, I think an re-13 cam would be better these days. all these mods done on a small bore head.
If you machine the zorst valves down to 27mm, there's no need to pocket the block. Still plenty big for a bored out 1098... :wink:
Another thing to watch though is if you fit these valves in a smallbore head they stick up 2mm extra. This reduces the valve spring tension and buggers up the rocker angle- reduces valve lift.
I fit a 12mm flat washer (1.6mm approx thickness) under the springs, and pack the rocker posts up 2.0mm.
Anybody wants some proper ground steel packers for this, I can make them... :wink:
PostPosted: Thu Apr 05, 2007 9:37 pm
i would use a 12g202 on a smallblock, cheap, easy to get etc.
if i only had $500 i would spend it on an exhaust, extractors and larger carb.
i would not use a RE-13 on a road going smallblock,
i would use it on a weekend warrior / club car.
PostPosted: Thu Apr 05, 2007 10:27 pm
how do i find out what kind of head i have?
PostPosted: Thu Apr 05, 2007 10:56 pm
There is a number cast into the top surface, under the rocker cover.
Generally it's near the middle, but on some smallbore heads it's up near number 4 cylinder.
There are other numbers cast near the thermostat on a few heads, these are generally not the ID numbers.
a few examples to look for-
smallbore heads-
2A628
12A1456
12G202
12G206
12G295
CAM4180
bigbores-
AEG163
12G940
12G1316
PostPosted: Thu Apr 05, 2007 11:29 pm
I would not put any Cooper S head on a smallbore 850-998-1098 motor, the valves are too big.
A Morris 1100S can work but there are things to watch out for.
If it's a smallbore motor, the best stock head is a 12G295, used on AH Sprite Mk 2A?, and Cooper 998.
Next best is the 12G202 used on 1098 (Mini and Morris 1100) and 997 Cooper motors. With a bit of a tickle they go fine on a road car.
Yeah, I emant in my case, one car of mine vs. another of similiar spec. I don't own any small bores, just 2 1275 minis. In fact I've never driven anything smaller in motor size. :shock:
PostPosted: Fri Apr 06, 2007 8:13 am
the numbers i could read are
2A629
..SM
....7
MOW06
(there were other under this but i couldn't make them out)
what king of head do i have?
i'm guessing SM stands for small.
can i use this head for anything?
PostPosted: Fri Apr 06, 2007 8:20 am
2A629 is a Morris 850/Mini Deluxe head.
1.090" inlets, 1.000" exhausts.
Nothing special. :lol:
Yes you can work it over- I used to- or go find a 12G202 which is a bit bigger inside to start with. They have 1.156" inlets and 1.000" exhausts.
Port that, deck it, then swap em. :wink:
PostPosted: Fri Apr 06, 2007 11:05 am
I had an RE-13 on a 1098 with a modded 12G202 on the road without any problems. Would do it again as well. You lose a bit of low down power, but if you're searching for power, you won't be looking below 3000rpm anyway! Good cam IMO...
Carl
PostPosted: Fri Apr 06, 2007 12:19 pm
There would be dozens of people on this forum running an RE13 in 1098 roadburners, daily driving, no problem. 8)
PostPosted: Fri Apr 06, 2007 1:25 pm
Yep 1152 with a RE13 Cam here with a Modded head and its the wifes Daily Drive :wink:
PostPosted: Sun Apr 08, 2007 7:42 pm
Go for mods to cylinder head and free flow exhaust and if budget suits go for a re13 cam
Mason :D
