It is currently Tue Jun 24, 2025 2:22 pm
Post new topic Reply to topic  [ 118 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
PostPosted: Thu Apr 05, 2007 12:57 pm
Ill do the rear disc conversion over easter......IN MY DREAMS.....
PostPosted: Thu Apr 05, 2007 4:32 pm
Stupid question for the day: have you weighed the disc set-up from either side versus the original drum?
72 Clubman and a 75 Van.
PostPosted: Thu Apr 05, 2007 5:11 pm
No, but im dam sure its heavier. Rotors and calipers weigh a bit!
PostPosted: Thu Apr 05, 2007 7:49 pm
I weighed a complete Honda brake conversion setup and a complete Cooper S setup 2 years ago, I think the Honda was about 1kg lighter. :wink:
PostPosted: Thu Apr 05, 2007 7:57 pm
Well there ya go then!!! Another benefit over fitting S brakes!!!
Kev did u get the email re the Caliper Kits?? K1380S is the P/N....PROTEX brand..
PostPosted: Thu Apr 05, 2007 8:01 pm
Yes thanks, I'll see if i can find some... :wink:
Thinking ahead, Saturday is get da Mokes day... 8)
PostPosted: Thu Apr 05, 2007 8:04 pm
Just b aware the the bouncy bouncy slide dust seals dont fit the best, seem to tight. So i just kept the original ones, soaked em in some armorall
PostPosted: Fri Apr 06, 2007 8:06 pm
Bedded the new brakes in this arv... Dragged em for a bit got em hot n up to temp, then stood on em a few times from 100kph..... YEP they certainly work better than drums..... Didnt quite get the rear wheels off the ground... but didnt lock em up either.... So the new S rear wheel cylinders did the trick....
Interesting feeling going from 100kph to 0 so quick.... I reckon my Dunlop Formula R's help as well!!!!
PostPosted: Fri Apr 06, 2007 8:16 pm
Yes they do stop, don't they... :lol:
I'm going to look at adapting Honda Civic rotors onto 8.4 drive flanges- so I can run S type CVs on da Moke. :wink:
PostPosted: Fri Apr 06, 2007 8:35 pm
Wouldnt it be nice to have 13's and have a little bit more space to play with.... Think of the options..... Im gunna have to make a effort at getting my back wheels off the ground.... Even if its just a little bit....
PostPosted: Fri Apr 06, 2007 8:42 pm
You need to limit the droop of the rear arms. 8)
PostPosted: Sat Apr 07, 2007 2:30 am
Easy, get shortened shockers or set some adjustables to max hard.
PostPosted: Sat Apr 07, 2007 8:43 am
Ive got lowered spax already and they are adjusted to the hardest setting. Maybe they wernt up to full braking capacity as i was still only bedding them in..... Got a fair bit of brake fade afterwards... Mite have to chase up some EBC pads......!
PostPosted: Fri May 18, 2007 2:52 pm
I'm only just going over this again...i'm using Bendix Metal King Pads and i struggle to get fade 8)
PostPosted: Fri May 18, 2007 3:09 pm
I gave my brakes a full on hard time, i dragged them at 80kph then stood on em quite a few times, probably more then i needed to. By the end of it i had a fair bit of fade. Im only using RDA pads as the brake specialists said that they are easier on the rotors. So they may not be the best pads in the world. But im not running it round the track any time soon.
