It is currently Mon Jul 07, 2025 10:31 pm
PostPosted: Mon Mar 26, 2007 9:11 am
i got a metro engine in my mini, now ive been driving it around with one of 92's supercharger kits on but my speedo doesnt work, Now im sure it was pushed into the gearbox properly but i can turn it at the speedo end so it obviously isnt connected right
i dont want to have to pull everything out again to check cos i just got it running mint so....
i assumed the metro speedo drive was the same as a mini? am i right?
any hints or tips on changing it without pulling everything apart again?
backyard performance............. Aint it the best
PostPosted: Mon Mar 26, 2007 12:12 pm
all i can say is you can get to the speedo cable from underneath :cry:
PostPosted: Mon Mar 26, 2007 10:37 pm
ha ha yeah good fun. It helps if you have an extra wrist joint!
PostPosted: Tue Mar 27, 2007 6:22 am
hahaha tried that already lol, pulled the borrom extra mount off ect... my hands are still too damn big, wish i was still 10, i had to do the same job on my dads mini and had the perfect hands to do so
ive got the cable out of the sleeve when i push it back down and twist it i cant feel it even trying to line up in the slot.... which is why i was wondering if the metro is maby a bigger drive
PostPosted: Thu Mar 29, 2007 6:52 am
ok had enough messing around!!
bloody rads coming out tonight, my hands are sick of being crushed and cut up (can barly move one of my fingers from last nights effort)
if i still cant get it im gng to mount a bike speedo on my rear hub and have a digital 1 lol
PostPosted: Thu Mar 29, 2007 8:57 am
use a long flathead screwdriver and a hammer, and tap the speedo cable "nut" loose
be persistent, it may take awhile.
i think getting the radiator in and out is more trouble than the speedo cable itself
PostPosted: Thu Mar 29, 2007 10:57 am
yea theres just no way in hell i cn get my hands in there to do it, rads coming out tonight, b***h of a job but i kind of have to, give me a chance to check pully clearances ect... on the supercharger manifold anyway (put together in a hurry cos i wanted to drive it)
 Post subject: cut metal...
PostPosted: Thu Mar 29, 2007 7:06 pm
You can remove one of the slats in the inner guard to make it easier to get at... :idea:
PostPosted: Thu Mar 29, 2007 7:34 pm
i hope you read this first...
http://www.ausmini.com/forums/viewtopic ... 370#165370
PostPosted: Fri Mar 30, 2007 6:19 am
havnt started it yet, read on turbo minis that metro drives are bigger than mini drives so my cable wont be any good anyway - can any one confirm?
if this is the case to hell with it im getting a digi speedo to run off the hub, will look pretty damn flash lol
PostPosted: Fri Mar 30, 2007 3:55 pm
sigh, i've done this job more times than i'd have liked to, and i'm telling you thats how ya do it.. it does work.
i think the bike speedo or whatever is dodgy.
