It is currently Thu Jun 26, 2025 3:19 pm
 Post subject: Fitting a flip front
PostPosted: Thu Dec 02, 2004 10:16 am
Hi guys,
Does anybody have, or know where I can get information on fitting a flip front to a round nose, I did a search on through the forum but it came up with 47 pages of results - I thought it might be quicker to ask outright.
Gig
67 Deluxe - Red and white
69 Deluxe - Sugercane Grey
PostPosted: Thu Dec 02, 2004 12:11 pm
well fitting a flip front (in NSW) requires it to be manifactured from the original body pannels, suspension pick up points must remain , front subframe bracing must be added and diagional braces must be added to further brace the front subframe, coming from the shock mounting points in the inner guard to the front pickup points on the subframe.
lookin for another clubby
PostPosted: Thu Dec 02, 2004 12:40 pm
That sounds the same in QLD But it has been done and All is fine
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
1970 Mini K, 1380cc, 1.75 HIF SU, 30 70 Cam, 2" Zorts
1969 Mini K, Stock Standard and Orginal. (Slow as Hell)
PostPosted: Thu Dec 02, 2004 1:09 pm
Where do you get them from?
PostPosted: Thu Dec 02, 2004 1:45 pm
flip fronts ?
PostPosted: Thu Dec 02, 2004 3:15 pm
Unless it has no front, or a damaged front, I wouldn't recomend doing the conversion. Too much hastle, and very little look any good.
PostPosted: Thu Dec 02, 2004 4:26 pm
flip fronts ?
Yep, them.
PostPosted: Thu Dec 02, 2004 8:23 pm
where to get a flip-front hmm
depends on how much money you have
lots of money then just go into fiberglass place and ask them to make one
(mold will prob cost round the 3g's mark to make and products round 1g's each)
otherwise you just have to find someone that already has a mold
was told there used to be a guy in brissy but don't know any more sorry
 Post subject: flippy
PostPosted: Thu Dec 02, 2004 10:09 pm
http://www.manchester-minis.cwc.net/tec ... front1.htm
This is a site to have a read of.. Hope this helps
Smiles
Baracade
PostPosted: Thu Dec 02, 2004 10:53 pm
Thanks Baracade,
Good stuff, Doesn't look too complicated but I won't try it on my first mini, cost is a major factor, especially if theres nothing wrong with the front end.
Gig
PostPosted: Fri Dec 03, 2004 9:22 am
im pretty sure any mini place can order one in for you,
PostPosted: Tue Dec 07, 2004 12:18 am
I saw on the Mini Mania forum a link to the best flip front I have ever seen. It used all the original steel panels and had internal releases just like a bonnet. I have been looking for the post but can't find it now. From the photo I would have said it was unpickable from standard.
Chris
Everything I like is either
PostPosted: Tue Dec 07, 2004 3:52 pm
dont get one.
PostPosted: Tue Dec 07, 2004 4:46 pm
Ditto. I reckon (My 2 cents) is they look cool in a show, but worse access to service items at the front of the motor. Perhaps make it totally removeable? If cost is a factor, why not fit some sort of quick release to the hinge mounts on the bonnet? I've seen some cool sets of four struts what hold the bonnet about a metre off the body to display it at shows - low cost & easy access.
PostPosted: Sat Dec 18, 2004 1:59 am
Do it.
But make it legal. :wink:
A one-piece flip front is a bulky and inconvenient item.... youre better off finding one that has a seperate bonnet.... it makes the small adjustments a whole lot less annoying.
Had one and loved it. 8)
