It is currently Mon Jul 07, 2025 4:50 pm
 Post subject: Camira Brakes
PostPosted: Tue May 31, 2005 11:29 pm
Hey,
If i wanted to do a disk brake conversion for my mini and someone was chopping a camira, what parts from the car do i require for the conversion?
Lucas
PostPosted: Wed Jun 01, 2005 11:18 am
you need the rotors and calipers....
68matic: "i havent seen much head in my life "
PostPosted: Wed Jul 06, 2005 10:52 pm
Okay so if I can get my hands on a set of calipers and rotors ... and i have a standard clubman with drum brakes, what other items do I need? Or can i just bolt the camira calipers and rotors on?
PostPosted: Thu Jul 07, 2005 3:19 pm
Anyone?
PostPosted: Thu Aug 04, 2005 5:59 pm
ANYONE?
Blackrz
(998cc Clubman)
- = :Zone 3 Goober: = -
http://photobucket.com/albums/y142/blackrz/?sc=1
"I Live My Life A Quater Mile At A Time"
PostPosted: Thu Aug 04, 2005 6:58 pm
you will need a bracket made up to bolt to the hub, then the caliper bolts to this. not sure what else is needed.
1974 Moke - 998cc
PostPosted: Thu Aug 04, 2005 7:16 pm
nuclear_mini's mate does a kit for this- all you need is the kit, + the Camira rotors & calipers. :wink:
PostPosted: Thu Aug 04, 2005 7:27 pm
Does anyone know how much the kit costs?, and if you can use 12 inch wheels?, thanks Tony :D
PostPosted: Thu Aug 04, 2005 7:33 pm
I think the kit was 200 odd bux. Plates etc were laser cut.
I forgot to add you also need S C/Vs and drive flanges, for the kit I saw.
nuke mini had them inside 12" wheels. Whether legal or not, I dunno, but they sure looked sweet.
PostPosted: Fri Aug 05, 2005 12:23 am
sounds good but
how much is it for S type cv's and flanges and are they easy to swap over?
PostPosted: Fri Aug 05, 2005 7:01 am
S C/Vs are on cheap at the moment from MiniSport in Adelaide, $65 ea I think. So Chong said... :wink:
S drive flanges list in Sydney at $93.21 ea, I'd try MiniSport for those too.
You need to pull the whole hub off, and driveshaft out, swap C/V on shaft, refit. I'd change the wheel bearings while you're in there, & fit Timken tapered roller kits.
Hell, you might as well clean all the hub up and paint it too....
PostPosted: Mon Mar 26, 2007 2:39 pm
THREAD REVIVAL....
Is this nuclear_mini's still around...? ? ?
interested in this kit his mate makes....? ?
PostPosted: Mon Mar 26, 2007 2:56 pm
he's dropped off the face of the earth...and has taken off with some members stuff he 'borrowed' while he was at it too :roll:
PostPosted: Mon Mar 26, 2007 3:37 pm
We'll find him.
The mini scene isn't that big in Australia.. 8)
PostPosted: Mon Mar 26, 2007 5:02 pm
True, but Australia is pretty big.
Users browsing this forum: No registered users and 43 guests
