It is currently Tue Jul 08, 2025 8:18 am
 Post subject: Head Works
PostPosted: Sat Mar 17, 2007 9:08 pm
I just bought a 12g202 head for my 1100, as i had the 2a629 on my car, and i was wondering how much i will have to shave off the head so that the CR will be good.
Is there any specific amount that anyone knows of from experience, and what is the most that I can shave of so as to avoid big problems involving valves hitting piston tops?
PostPosted: Sat Mar 17, 2007 9:12 pm
Another question I've got, with the valve rockers, on the presses steel type, is it possible to change the actual tappet that hits the valve? :?:
PostPosted: Sat Mar 17, 2007 9:17 pm
The Forkmeister
I believe that 50thou is about the norm off a virgin head, but you might want to get the good doc to confirm this.. :wink:
Gerg
May the fork be with you.
PostPosted: Sat Mar 17, 2007 9:21 pm
thanks mate, He already sid that to me in a previous post, i think I'll stick to the 50 thou
PostPosted: Sat Mar 17, 2007 9:23 pm
You can take around .100" off a 202 head usually, any more and they are too thin in the deck.
I would limit it to .080" for reliability.
Original thickness was 2.750" approx, check before decking it.
Standard valves will not hit the piston tops with this head.
Those pressed steel rockers have a hardened insert at the valve end. If worn it gets refaced, not replaced.
If doing them up, replace the shaft and bushes if worn.
These rockers are good, better than the sintered powdermetal ones used from mid-70s on. :wink:
PostPosted: Sat Mar 17, 2007 9:31 pm
thatnks Dr Mini, you just saved me some headaches and hassels and money too. :D
 Post subject: Where are you going
PostPosted: Thu Apr 05, 2007 10:06 pm
Before you chop the head, consider doing the sc12 supercharger conversion. You can save the head machining and will end up with a more comfortable ride with buckets of torque and a smooth idle.
