It is currently Sat Jun 21, 2025 3:50 am
 Post subject: 13" geMINI wheels
PostPosted: Fri Apr 23, 2004 11:17 am
does anyone know if a set of mags of a gemini will fit on a mini?
has anyone done it?
iv heard that the stud pattern is just about the same, but im not sure on the offset?
cheers gordie
ps im aware of the normal mods needed to fit 13's to a mini, (flares, cutting, etc)
PostPosted: Fri Apr 23, 2004 7:23 pm
Be very careful. Minis are 4" (101.6mm) PCD (pitch circle diameter) the GeMINI is an Isuzu, so probably 100mm PCD. If you try to use 100mm stud pattern wheels you will f**k the wheels and break your wheel studs... :cry:
PostPosted: Fri Apr 23, 2004 8:44 pm
o ok, what about if a had the holes inlarged? and used bigger nuts?
or i was thinking mabye getting them redrilled?
would this be a safer way to go?
cheers gordie
PostPosted: Fri Apr 23, 2004 10:10 pm
You have to relocate the holes or bore it and fit inserts at 4" PCD.
Probably cheaper (and safer!) to buy proper wheels...
PostPosted: Sun Apr 25, 2004 2:22 am
...its been a while, but my friend had a set of alloys redrilled and sleeved to suit his charade (108pcd i think) and it cost him under $100 to do the lot.... they've been on the car for 2 years now without a problem...
but there are other alloys out there, nicer than gemi rims....
PostPosted: Mon Apr 26, 2004 9:25 pm
thanks for the replys (Y)
so where would i get them redrilled? is there a place that will do it?
PostPosted: Mon Apr 26, 2004 9:36 pm
In Tassie, a toolmaker would probably be your best bet, they will do it accurately, not f**k it up.. :wink: They do charge $$$ though..
Users browsing this forum: No registered users and 24 guests
