It is currently Tue Jun 24, 2025 6:45 am
Post new topic Reply to topic  [ 411 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 28  Next
PostPosted: Wed Feb 14, 2007 6:21 am
ooops :)
I thought it looked a bit low....... :?
1962 Morris 850.....with a 1310
1998 Toyota starlet.....161.1hp atw
PostPosted: Wed Feb 14, 2007 9:45 pm
hehe, that is low..... are you still going to run the hydraulics on her like you posted ages ago? I have been obsessing over hoodrideratrod beetles and other vw's of late and love the erdiculously low look. I think they bag them and drop them on the guts when parked. I would love to see a mini doing that... keep us informed and keep up the good workgordo and mr enforcer.
DAVID
PostPosted: Thu Feb 15, 2007 8:52 pm
Yes i am still going to run the hydraulic suspension. Ill just have to make up some bigger bump stops so it dosnt bottom out... Just need to knock up a frame to hold the 2 pumps and the 4 batteries :roll:
Life's a garden.... Dig It!
PostPosted: Fri Feb 16, 2007 6:02 am
YAYYYYY
PostPosted: Mon Mar 12, 2007 7:28 pm
floss wrote:
YAYYYYY
A little somthin of an update that'll interest you... Next step is to get the pumps connected up and get this car moving :D Going to have a pump and 2 batteries on each side... And the pumps im going to run only wiegh 20kgs each :shock:
PostPosted: Mon Mar 12, 2007 9:14 pm
Hey,
That is cool
Are you sure you want to use compressors?
I hear the noise gets annoying and the condensation can rott the system. They also say it freezes in the cold but that wont be a problem for aussies.
DAVID
PostPosted: Mon Mar 12, 2007 9:19 pm
They are hydraulic pumps, not air compressors... So they will be pumpin hydraulic fluid around the car. Just like the yanks do it
PostPosted: Mon Mar 12, 2007 10:02 pm
im very keen to see how the hydraulics go
gd luck
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Mar 12, 2007 10:12 pm
Siclad wrote:
1970 mini K wrote:
i thought your ment to put the bog on bear metal....
not what ive been taught...
stripper disc-->deoxidine-->metho-->compressed air-->etch-->hi fill prime--> guide coat--> rub 'flat' with 120--> bog etc etc
they may do it differently in other places :P
ive been told not to stick it to primer, when it heats up it can peel of the primer, and sticks better yo bare metal
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Tue Mar 13, 2007 6:37 am
ohh... as the name hydraulics would suggest. Sorry. I have been reading about airbagging lately and got my wires crassed as per usual.
It is going to be very cool to say the least.
David
PostPosted: Tue Mar 13, 2007 8:18 am
Gordo wrote:
floss wrote:
YAYYYYY
Good stuff Dan,
I can't see the pics because I'm at work but its good to read you are making progress.
JC
PostPosted: Tue Mar 13, 2007 3:41 pm
JC wrote:
Gordo wrote:
floss wrote:
YAYYYYY
Good stuff Dan,
JC
I only just re-read my post... And i meant that the batteries are 20kgs each. The pumps are a little lighter atm but thats without fluids. And the progress is ever so slow :(
PostPosted: Mon Mar 19, 2007 7:17 am
Hi guys, just registered, and like what i see here in this thread. will be keeping an eye on this van...
Size DOSEN'T matter
PostPosted: Sat Mar 31, 2007 9:23 am
floss wrote:
Hey,
That is cool
DAVID
Even though he is using hydro's and not bags, if the compressors are set up properly on a airbag system with water traps and regular attention you shouldnt have problems with condensation.
Aesome idea putting adjustable suspension in a mini :) Eventually i want to run a van with airbag suspension :)
Mini Less at the moment :( Broken Again
PostPosted: Mon Apr 23, 2007 6:51 pm
Another slow and not much happening update
And im in the middle of a dummy set up of the hydro's to see what else im going to need. And to see if its all going to work
