It is currently Tue Jul 08, 2025 11:01 am
PostPosted: Tue Mar 06, 2007 10:14 am
Can anyone tell me if theres any way to tell if a gemini starter motor is disengaging from the flywheel by sound or any other method rather than having to pull the thing out again?? :?
TasTyger
PostPosted: Tue Mar 06, 2007 4:04 pm
It would be making a really loud grinding/gear noise if it's not disengaging as the engine would be turning the starter motor.
Is there any other symptom you can provide to help out?
Daniel
PostPosted: Tue Mar 06, 2007 6:54 pm
Sometimes you need to put a thin spacer between the Gemini starter and the flywheel housing, it depends where the flywheel & ring gear are sitting.
but don't just use flat washers, the starter will rock about. :wink:
