It is currently Tue Jun 24, 2025 7:26 am
 Post subject: a bit about OZNOS
PostPosted: Thu Apr 22, 2004 1:41 pm
hey, just a cut and copy from a email i got from the place...
Yes, we do have a kit to suit your turbocharger Mini. There is actually two choices, both are a single nozzle wet system. Part number 80201 is an adjustable 6psi fuel pressure kit and for your application it would come with 25 - 50 horsepower jetting and will cost you $889.00 including GST. The second choice is part number 80181 is an adjustable 40psi fuel pressure kit and would also come with 25 - 50 horsepower jetting and costs $939.00 including GST. With both kits you take the fuel directly from the fuel rail making sure that it delivers a minimum flowing fuel pressure of 6 psi for the 80201 kit and 40psi for the 80181 kit, plus rising 1 psi for every 1 psi of turbo boost.
If the engine is intercooled the nozzle will have to be installed after the intercooler and you will then require a rising rate regulator that will increase the kits fuel pressure by one pound for each pound of boost. if it is not intercooled, then the nozzle will go on the outside of the turbo. Either way the incoming temperature will be reduces as the ingoing charge of nitrous is at minus 60.5 degrees celsius, thus effectively being another/additional intetrcooling method.
Both kits are capable of making up to 200 horsepower with just a jet change
All OZNOS kits are wet systems. The kit comes with a WRITTEN LIFETIME WARRANTY, so that if any part of the kit fails, if we cannot make it work like new we will give you a new piece.
Because all OZNOS kits are adjustable, you can use it on a stock motors or if you have installed better pistons, then higher horsepower settings can be used. So you do not have to do major mods to the engine to run a nitrous kit.
You have the choice of running the smaller settings through your complete rev range or run the larger settings and turn the nitrous kit off with a boost switch. Some people even prefer to reduce the boost and run more nitrous horsepower. With the kit being adjustable, you get to choose which combination of how you want to add the horsepower.
The kit comes with a full set of instructions so the average handyman mechanic can install his own kit, we do not do installations.
With OZNOS kits you use a BOC bottle. It costs $0.28 per day (approx $8.40 per month) rental and they maintain it, plus have exchange bottles available so you don’t have to wait around for someone to fill your bottle. The BOC bottle is Australian Standards Approved as well. When you buy an OZNOS kit you will get a 10% discount on the nitrous through BOC, all the details with regards this are included in the kit instructions. The imported bottles are not Australian Standards Approved and BOC will not fill them. With Lawyers and litigation the way it is today, we feel it is far better to rent the bottle and let BOC have that problem should one arrive. I must add the possibility of there being a problem is negligible, but it would still cost to prove that point. Refills cost just over $100.00 and you use one pound of nitrous every 20 seconds when running a 50 horsepower kit. The bottle holds 14 pound of nitrous.
Accessory items that you may consider are listed below:
Part Number 81110 Nitrous Filter @ $113.00, if you buy it with the kit.
Part Number 81130 Nitrous Pressure Gauge @ $95.00, good for fine tuning your kit.
Part Number 81250 Turbo Pressure Switch @ $84.75, for turning the kit off when using the higher HP settings when the turbo comes on boost.
Part Number 81260 6 psi fuel safety switch (to suit the 80201 kit)
Part Number 81264 40 psi fuel safety switch (to suit the 80181 kit)
Part Number 43700 Rising Rate Regulator for intercooled engines is $199.95
A disarming kit is included with every OZNOS Kit.
If we can be of any further assistance, please feel free to contact us again.
PostPosted: Thu Apr 22, 2004 3:37 pm
Interesting- are U allowed to have this on the road in Tasmania? :roll:
Up here in `Carr cuntry' they take your right nacker if you use it on the road, or even have the bottle connected.... I think in some states you can't even have it on the car. :cry:
PostPosted: Thu Apr 22, 2004 3:49 pm
Yep in WA, you cant have a Nitrous Kit installed...
PostPosted: Thu Apr 22, 2004 5:09 pm
I dont know if u can or cant have it, but the cops down here properly wouldn't know what the hell it was!!
PostPosted: Thu Apr 22, 2004 5:12 pm
I find it hard to believe that they are that dense ;)
PostPosted: Thu Apr 22, 2004 5:18 pm
yeah I was only joking round... :lol:
PostPosted: Thu Apr 22, 2004 7:34 pm
i thinnk that oznos is confused withh the bini because it says "fuel rail " WTF? only fuel injected cars have fuel rail
lookin for another clubby
PostPosted: Thu Apr 22, 2004 7:55 pm
Good point... :wink:
PostPosted: Thu Apr 22, 2004 8:27 pm
yeah i didnt get that bit :?
PostPosted: Thu Apr 22, 2004 10:08 pm
scuse me. Diesels have fuel rails too. :P
But back to the post, Nitrous is just a quicker way to wear out, or break your engine.
"He's always been a dickhead, He always is a dickhead, He will always be a dickhead. So stop complaining when he acts like one."
PostPosted: Thu Apr 22, 2004 10:24 pm
Let Vin Diesel & Ronald McDonald guide you in your quest for NNNNNNAAAAAAAWWWWWSSSS......
I live my life a quarter pounder at a time...And for those 500 calories or more.... Im free.
I need FRIIIIIEESSSS !! Two of them. The big ones. And Harry, i need them by tonight.
Amatures dont super size , Ive seen the way you eat !! You got a big mouth, youll blow yourself to pieces.
Whats the retail on one of those ? More than you can afford pal,5 star beef burger.
Your lucky the double shot of bbq sauce didnt blow a seam on your nugget box.
Whoa, There she is, 2 pounds of pure mickey d's beef. My dad ate it in 9 seconds flat. There was so much special sauce, the juices actually dripped onto his chin coming off the line. Whats your time? I havent tasted her yet, she scares the crap outta me.
My grill topped out at 140 degrees today. I need more charcoal, 2 bags, the big ones.
So what are you eating ? Oh you gonna make me look under the bun to find out.
Its not how you stand by your burger, its how you eat your burger.
You almost had me ? Almost had me ? You NEVER had me. You never had your burger..... Granny biting, not double chomping like you should!!!!
Now me and ronald mcdonald here are gonna have to rip open the counter, and replace the onion rings you fried.
Dont do it, ill bet you hes got at least a triple cheeseburger under that bun...
dwightgunning.com
PostPosted: Fri Apr 23, 2004 9:28 am
ha ha ha, that is one of the funniest things ive read in ages!!! well done!!
PostPosted: Fri Apr 23, 2004 9:38 am
I don't get it?????? :?
PostPosted: Fri Apr 23, 2004 10:59 am
they are quotes from fast & the furious, but changed a bit to be about mcdonalds and fast food!!
PostPosted: Fri Apr 23, 2004 11:21 am
haha...seen that a couple of times..still funny every time
can i ask why u want nitrous josh? unless your going to drag the car its pretty much useless.
[Maverick] 1971 Mini K
