It is currently Mon Jul 07, 2025 8:46 am
PostPosted: Fri Jan 26, 2007 10:11 pm
The UK 1100/1300s have a tap on the heater hose to stop the water flow when it is off.
The Aussie 1100/1100S have water circulating through the heater all the time to give more cooling for Australian conditions.
The radiators in the 1100s are bigger than the ones in Minis.
PostPosted: Sun Jan 28, 2007 4:19 pm
My thermo fan. I've never seen another like it. But it fits the radiator perfectly. I bought it form Brickworx with a sender which goes in the bottom hose. Steve said it was from a Jap Rover.
PostPosted: Sun Jan 28, 2007 4:39 pm
Give Ash some flowers Nick .
Slinkey, you are right, that is a very neat install that looks like its supposed to be there.
PostPosted: Sun Jan 28, 2007 4:47 pm
If you look in the top left corner you can see a 'daddy longlegs' hanging out! :lol:
PostPosted: Sun Jan 28, 2007 5:56 pm
nice, great fit aswell, ill be taking my engine fan off and just puting a slim line electric fan on the engine side of the radiator and see how it goes, and if it heats up, i have another spare electric fan which i will put under the guard as you have done to yours.... all i have to look out for is if the fan a suck fan of blow.... i no i have a suck fan so all i need now is a blow fan..... ill keep yas informed on how it goes
:wink:
@#$%Things are not what they used to be
Missing one inside of me
Deadly loss, this can't be real
Cannot stand this hell I feel
Emptiness is filling me
To the point of agony
Growing darkness taking dawn.
PostPosted: Sat Feb 10, 2007 8:22 pm
Hi
I was wondering how the sender fits into the bottom hose. is there a sender boss / adaptor that fits in between the rad and the bottom hose
Thanks
B
PostPosted: Sat Feb 10, 2007 10:00 pm
The bottem hose has about 2inchs cut out of it. A t-piece is put in and the sneder is tightened into the threaded hole in the t-piece.
It's exactly the same as it was on the Rover, but the hose I was giving with the sneder and t-piece in it was a bit dodgy so I cut up my new one. Nice fit, getting to the wires would be a bugger, but I have rather skinny hands, so to me, no problem.
PostPosted: Sun Mar 18, 2007 4:42 pm
The Forkmeister
No wonder the poor thing was running a tad warm !!!
massive cores... :shock:
Hi flow vs no flow.... :wink:
hi flow pump on and new thermostat in.
Doh! why didn't someone tell me the fan was in the wrong way !!!! :oops:
Any way, now that i've figgered out how to post pics,(i hope ! ), I will post some more of the extra radiator I put in last week...
May the fork be with you.
PostPosted: Sun Mar 18, 2007 8:23 pm
Great pics, your old water pump with the pressed metal style of impellar just don't work.
And sorry to say, looks like your fan is on backwards :(
Steve
PostPosted: Sun Mar 18, 2007 9:28 pm
The Forkmeister
I was careful to put the fan back on the same way I took it off, but than found out that the idiot that owned it before me had been driving it around for god knows how long with it in the wrong way !!! :roll: , so I had to remove and re-install all over again.... oh well, at least I'm good at it now. :wink:
