It is currently Tue Jul 08, 2025 12:11 pm
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Thu Feb 08, 2007 7:25 am
borgy wrote:
i can get you Hayabusa quads for $600 inclusive straight off a wrecked bike...... They are 52mm am the mouth then taper to 50mm at the butterflies then taper to 48mm at outlet or valve side....... Injector ports are down stream of the butterflies........ Put them on mine when it was n/a and only made 4 or so hp at top end with a big pelenum up stream of butterflies....... When i went boost though they definatly helped with air flow........... :lol:
Borgy,
What was the depth (back to front) of the setup once installed.
Does it take up less room than stock manifold.
Tricky
PostPosted: Sat Feb 10, 2007 8:49 pm
Borgy - PM'd Re: the Quads off the 'busa
I am torn because the stock computer will not handle them by the looks of things and That's why I am staying with a TD04 (the stock computer runs well with a TD04) I am really quite keen to bling up my engine bay with some big quads especially if they help with a bit of throttle responce the turbo will spool quicker thats the plan anyways.
I will try and work out if it's going to fit and if it's a good idea. I might run into master cylinders, but i'll have a look and see if the busa quad's will keep you guy's posted.
and a few conversions:
13B Extend in a 1600
