Yeah i saw borgy's tiger in Miniworld and it said that it was turbo and used the R1 throttle bodies (sorry about the confusion), i was hoping that someone might have some pics of what he has done or what the setup roughly looks like.
I think i have some but might take a day or two to dig out.
Is it basically going to be a log coming from the turbo into 4 throttle bodies and then each one going into the inlet port.
Correct.
Will this increase performance at all? - i suppose it will as you are getting more air in as long as your inlet pipe from turbo is big???
Yes it should, the nissan SR20 quad throttle body motors have more power.
Will i need to run an aftermarket computer? How do you go about tuning?
Yes, You will have to have it tuned on a dyno.
Can Bike throttle bodies be used and engineered/registered?
Good question, not sure? would like to know.
Dan
