It is currently Mon Jul 07, 2025 7:06 am
PostPosted: Tue Jan 30, 2007 9:25 pm
do you think the hesitation is from a weak mixture, so the larger pump and idle jets and smaller choke , will help richen the idle mixture up, to help stop the hesitation
77 Leyland Clubman
1293cc, LCB extractors, pulsar dizzy (recurved), cooper s disc brakes, 40DCOE Weber
PostPosted: Fri Feb 02, 2007 7:38 pm
:cry: i want a webber for my 1098, any ideas on were to get one...
@#$%Things are not what they used to be
Missing one inside of me
Deadly loss, this can't be real
Cannot stand this hell I feel
Emptiness is filling me
To the point of agony
Growing darkness taking dawn.
PostPosted: Sun Feb 04, 2007 9:18 pm
Ahh I finally solved the flatspot probelm on the weber and it only cost $5, i was missing a little pressure valve in the float bowl at the bottom, its a little brass screw with a ball bearing in it, with out this the pump jets dont work properly, although they still do squirt fuel, just much weaker.
So now all i can say is the weber is 10 times better than the su, Works a treat all through the rev range. If anyone gets the chance for a weber or simillar carb get it.
77 Leyland Clubman
PostPosted: Sun Feb 04, 2007 9:41 pm
8) sweet as thats good that ya sorted it all out, i just need to find a weber to get rid of my HS4... no of any were there is one for sale.
PostPosted: Sun Feb 04, 2007 9:45 pm
there a weber on ebay now 40dcoe looks like its in good cond
http://cgi.ebay.com.au/Weber-40-DCOE-Ca ... dZViewItem
77 Leyland Clubman
PostPosted: Sun Feb 04, 2007 10:03 pm
woohooo ill check it out thanx for that, 8)
 Post subject: 1078 plus 40mm webber?
PostPosted: Mon Feb 05, 2007 5:24 pm
Hi,
Just put my 998 +100 back into my van. I figure that makes it a 1078. feel free to correct me on that. I am about to recieve a 40mm dcoe with a longman manifold (not sure what length-ebay purchase). The carb is jetted for a 1098. my engine has a cooper 998 cam and a 12g295 head. pistons are flat tops.
Any advice on whether or not the carb is likely to need new jets/air correctors.
Thanks
Mike
PostPosted: Mon Feb 05, 2007 7:11 pm
Do you know whats in the weber, eg jets chokes etc, mine seems to work quite well with the setting i have
77 Leyland Clubman
PostPosted: Mon Feb 05, 2007 9:16 pm
resident alien
resident alien
I have a 40DCOE on a 1098 but have no idea what the setup is :oops:
 Post subject: 40DCOE webber on 1098
PostPosted: Sun Feb 11, 2007 7:54 pm
Hi guys, i have fiddled with a few webbers on minis, like i saw id probally up size to 34mm chokes, and go back to 3.5 aux. venturies, this should help the flat spot, cheers..
