It is currently Sun Jul 06, 2025 7:32 am
PostPosted: Mon Jan 22, 2007 9:55 pm
willy wrote:
A+ are the way of the future, and will see a longer survival of the beautiful A-series engine.
Might be so, IF they still made em. They don't... :cry:
Unfortunately, some bits for these will run out just as for A series, it's happening already. Look at gearbox gears for example.
PostPosted: Mon Jan 22, 2007 10:00 pm
This is true... but there are a lot of A+ engines about... lots and lots more than A series (serviceable/running items)
And with the massive new parts inventory, it makes owning a Mini very enjoyable and resassuring that spare parts are only a phone call away 8)
PostPosted: Tue Jan 23, 2007 9:32 am
this cant be said for everyone (esp. the doc)
but most people who have an A+ prefer it to an a series. and most people who have a a series like it more then a A+.
i'm a A+ fan, but sometimes i wish i had a A series, its easier (i found) to find parts for A series then A+ (clutch stuff, carb kits etc)
etc etc etc
PostPosted: Tue Jan 23, 2007 6:30 pm
etc etc etc
Well I've got one of each running, so Nyerrr.
In modified form with bigger cam carbs head pistons etc there is bugger all difference. Run wot ya brung, dudes.... 8) :P
PostPosted: Tue Jan 23, 2007 8:57 pm
thats why i said it cant be said for you, you have both
PostPosted: Fri Jan 26, 2007 5:20 pm
http://www.minifinity.com/modules.php?o ... s_and_an_a
PostPosted: Sat Jan 27, 2007 9:09 pm
stolen from minimania
A-series vs. A-plus engines
The A-plus engine is the result of development efforts carried out on the A-series engine in the late 1970s/early 1980s for the Metro. The A-plus engine was available in 998cc and 1275cc forms, and very briefly in 1098cc form. The blocks and gearboxes were introduced to the Mini range at different times starting in the early 1980's. Key features are:
* Increased block strengthening plus thicker gearbox mounting flange.
* Gearbox and drop gears redesigned for lower noise and increased strength.
* Dipstick is incompatible between A-series and A-plus.
* Alternator brack altered.
* Distributor clamp altered.
* Verto clutch (reduced pedal effort).
A-series and A-plus engines are interchangeable, though gearboxes are only interchangeable if an adapter drop gear is used.
PostPosted: Sat Jan 27, 2007 9:13 pm
...the last line just means use a primary gear to suit the A+ or A series drop gears.
Nose of cranks is the same.
Over here, A+ primaries are not real common unless you go buy new.
