It is currently Sun Jul 06, 2025 5:23 pm
 Post subject: Whats my 998?
PostPosted: Tue Jan 23, 2007 2:05 pm
Whats my motor?
99h791p 424785
its a late 998 (UK) i think, it has the camxxxx head, with solid rockers etc,
but it also has a 1/2 inch lobe'd camshaft, and the simplex chain is missing its tensioner, there is very little sign of wear, and no evidance that its ever been apart, should a 998 have this cam?
discussion welcomed :P
PostPosted: Tue Jan 23, 2007 2:24 pm
Mini 1000 1974 on with dished pistons
Edit: source http://www.miniresource.com/engine.php
David L
PostPosted: Tue Jan 23, 2007 2:36 pm
that sounds right, what denotes 74 on?
PostPosted: Tue Jan 23, 2007 6:34 pm
the 791
later ones 77 on with smog head were 99H/AJH something. :wink:
PostPosted: Tue Jan 23, 2007 7:25 pm
hmmmm ok, we never got the smog head here, but its got the unleaded head.
oh dear, to confuse this further, its got an a+ gearbox, with a 3.4 diff.
this is the second similar engine i have pulled down in the last year :?
and whats with this cam, its slot drive, with 2 rings, does the a+ 998 block have ribs?
also the actual engine number seems high.
i dont mean to sound like ive found anything amazing, its just a confusing stock 998
PostPosted: Tue Jan 23, 2007 10:45 pm
You can identify your cam from Vizards book - How wide are the cam lobes?
David L
PostPosted: Wed Jan 24, 2007 1:35 am
does the cam have 2 rised rings between lobe 3 and 4?
and vizards book does not cover all A+ cams
Rover 214 atm ....
PostPosted: Wed Jan 24, 2007 4:52 am
yes, 2 rings between 3 and 4, 1/2 inch lobes...
hmmm, i really should buy visards book. :)
PostPosted: Wed Jan 24, 2007 5:23 am
than it should be the normal low compression, 8.3:1, 998ccm A+ cam
Timing: (Intake): 5/45 (Exhaust): 40/10
Duration (Intake): 230 (Exhaust): 230
Rover 214 atm ....
PostPosted: Wed Jan 24, 2007 5:29 am
nice and mild then :lol:
thanks for the info! its getting a fresh-up and a nice 202 head, out of interest, what are the specs of a stock pre a+, spider-drive 1275 cam?
PostPosted: Wed Jan 24, 2007 6:56 pm
i don´t know what a "stock pre a+, spider-drive 1275 cam" is.
what engine? or name of the cam?
Rover 214 atm ....
PostPosted: Wed Jan 24, 2007 7:00 pm
just the austin/morris 1300 (ado16) cam, its actually a NZ 1275gt cam, which is an a+ block, crank, rods, pistons, with an a-series head and cam :roll:
PostPosted: Wed Jan 24, 2007 7:47 pm
not sure but could be this one:
Timing: (Intake): 5/45 (Exhaust): 51/21
Duration (Intake): 230 (Exhaust): 252
if it is this one, it should be timed in at 106° ATDC and not 110° the manual says
Rover 214 atm ....
Users browsing this forum: No registered users and 21 guests
