It is currently Sat Jul 05, 2025 9:12 pm
PostPosted: Fri Jan 05, 2007 8:47 pm
Hi all.
I've been told that when you fit the Ignitor electronic conversion to the Lucas dizzy for a '73 car, that the rotor button has to be changed for a different one.
Anyone struck this & can help with a part number?
Thanks.
PostPosted: Fri Jan 05, 2007 9:38 pm
Mowog wrote:
Hi all.
Thanks.
This is not true. If you get the right ignitor for the dizzy, the rotor fits as normal.
I've fitted up 3 of these.
The magnet thingy fits down over the cam, it doesn't interfere with the rotor at all.
I buy them here, much cheaper than in Oz.
http://www.vintageperformance.com/retro ... /lucas.htm
 Post subject: Ignitor ignition module
PostPosted: Mon Jan 08, 2007 6:12 pm
Dr Mini.
Once again, thank you for your help. I've checked out the link & the saving is worth it. Cheers
Scotty.
