It is currently Sun Jul 06, 2025 3:59 am
 Post subject: New Cam Followers
PostPosted: Sat Dec 30, 2006 2:48 pm
Okay, so how important are new followers really? I am currently putting together a bitsa 1100 motor, nothing special but I have a good Camtech 621 sitting here, thought I may as well put it in. Don't have matching followers for it. It isn't a freshly ground cam its out of a motor. So whats gonna happen if I put good second hand followers in?
PostPosted: Sat Dec 30, 2006 3:01 pm
It depends how good they are.
Put a straightedge across them, there must be a visible convex surface. If flat or hollow or chipped at all, bin em.
Cover the cam lobes and lifters with Castrol LMM molygrease, and then start & run it in for 10+ mins at 2000 rpm.
Should be OK. :wink:
I'm doing the same thing on this stroker 1412, my spare RE13 cam and lifters has only done 1200 miles, so it's all going into this other block. 8)
GR said will be OK.
Last edited by drmini in aust on Sat Dec 30, 2006 3:03 pm, edited 1 time in total.
PostPosted: Sat Dec 30, 2006 3:03 pm
So effectively bed the cam/followers again? My next question was going to be what to lubricate the cam with so thanks for that tip :)
I have a few sets of used followers, I take it I can mix and match as long as they are in good condition like you say?
PostPosted: Sat Dec 30, 2006 3:04 pm
yes, pick the best ones. :lol:
PostPosted: Sat Dec 30, 2006 3:10 pm
Just had a look at my two sets of used followers, both are basically flat. I do have a new set of followers, but they are sposed to be for a different engine. Looks like a may have to use em anyway :(
PostPosted: Sat Dec 30, 2006 3:14 pm
PM sent. :wink:
