It is currently Sun Jul 06, 2025 11:53 am
 Post subject: Duel circuit brakes
PostPosted: Tue Dec 26, 2006 6:31 am
Hi,
I want to upgrade my mini brakes to a duel circuit system.
I have disks on the front with drums on the rear.
I have heard that a Mazda master cylinder will do the job.
Anyone have details on which cylinder to use and any modifications required?
Do you still need the pressure reducing valve on the rear sub frame?
PostPosted: Wed Dec 27, 2006 3:19 pm
The late clubbies used a dual circuit master cylinder. You would be well advised to use one of those rather than trying to modify and fit a mazda component. That way you are covered should you ever be involved in an accident and your car is examined and found to have non standard components that have not been engineer approved.
I am aware that with a disc / drum setup you will need to fit Cooper S rear wheel cylinders (which have a smaller diameter bore) to prevent rear wheel lock up under emergency braking which may spin you around. Very messy at traffic lights in the wet.
PostPosted: Fri Dec 29, 2006 10:07 am
I have used the clubman duel circuit brake master cylinder in the past and found it hard to get a good solid pedal. This time I will be using Cooper S disks with a booster which will make this worse.
Any hints on getting a solid pedal using the clubman duel circuit cylinder, or am I dreaming?
PostPosted: Fri Dec 29, 2006 10:24 am
I'm running one in Barney with S brakes and no servo, pedal is nice and hard. :wink:
Why would it not be?
PostPosted: Fri Dec 29, 2006 10:29 am
I have no problems with the pedal pressure - its as hard as a rock. I dont have a booster and I regularly stand on the brakes to pull it up. Mini is a clubman with cooper S brakes.
The hydraulics are a sealed system and once they are fully bled with the rear drums properly adjusted you should have a high pedal and a solid pedal.
It may well be the master cylinder (or the wheel cylinders) are worn and allowing fluid to pass by the pistons and rubbers. Also check that the little locating pin between the top of the pedal and the master cylinder push bar are properly fitted and not worn.
Mini's in general have some issues with brakes but pedal presssure is not one of them generally.
PostPosted: Fri Dec 29, 2006 10:41 am
The LS as far as Im aware has the dual circuit master I have 8.4 disks drums rear and I can though don't choose to slam them on in the wet and they pull me up instantly.
PostPosted: Fri Dec 29, 2006 12:06 pm
I've got dual leyland cyl (mini LS etc) with the original 'S' discs, no booster. I rebuilt it and have no problems with braking on the street, pedal is firm. It's a bit harder to use than with a booster but I prefer the 'feel' without.
Daniel
