It is currently Fri Jul 04, 2025 2:30 pm
Post new topic Reply to topic  [ 56 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Fri Dec 22, 2006 8:18 am
Look how much metal is on that puppy! I bet a lightenned verto is still 5kilos heavier than stock pre-verto :lol: :P
PostPosted: Fri Dec 22, 2006 11:47 am
Verto clutch setup is weird compared to a normal Mini- flywheel is not bolted to the crank, the diaphragm is... :shock: :lol:
PostPosted: Fri Dec 22, 2006 12:05 pm
If you think they are strange you should see the clutch on an Austin Montego. :wink:
PostPosted: Fri Dec 22, 2006 12:28 pm
Yeah, I was a bit worried about the whole verto set-up, hence my re-engineering of the clutch slave cylinder and arm to use the old style (I needed the space)
DOZ
PostPosted: Fri Dec 22, 2006 1:20 pm
never had an issue with the verto, but when i do im sure your all going to hear about it :D nearly 5 years and still going strong though, not bad
 Post subject: Re: Lightened flywheels
PostPosted: Sun May 17, 2020 3:24 am
Matt TheMiniMan has done heaps like this, with holes in, he's never had one break.
Likewise GR.
My 1310 regularly saw 8000 on the track, no problem.
I think facing them off .200" is fine, I'm just wary of drilling big holes or (worse) milling slots thru them.
If you want it that light, go buy a steel one.....
BTW if turning them, make sure there's a nice big radius on the lathe tool, you don't want a sharp corner at bottom of cut. :wink:
And they MUST be rebalanced afterwards.
@drmini in aust do you have a past comment/explaination on how you do the balancing on these after machining?
Sent from my HD1901 using Tapatalk
PostPosted: Sun May 17, 2020 8:26 am
Likewise GR.
I am retired now but I used to take them to Graham Russell. With or without a crank.
He balances the crank or uses his own,
Then bolts flywheel on and balances that, then adds the backplate and does it too, finally adds the diaphragm, uses which of 3 positions that shows best assembly balance. This all done on a dynamic balancer.
PostPosted: Sun May 17, 2020 12:00 pm
Likewise GR.
Ahhh makes sense Doc. Thank you.
PostPosted: Sun May 17, 2020 3:28 pm
willy wrote:
GR is doing my flywheel.
I have heard a one-piece is desirable, as it does not tend to 'weld' onto the taper of the crank, due to the big difference in metal types.
So I will hunt down a one-piece before Friday when I fly over to Syd :lol:
I am taking a backing plate too, he is lightening that also.
Might have been a freak incident but I had a 1 piece off my 1300GT engine weld itself to the crank making both parts unusable.
PostPosted: Sun May 17, 2020 6:26 pm
This is what I’ve just finished the other day, similar to what Matt Read does only the slow way by hand. It came in at roughly 13lb. Just going on a road car, 1150cc with supercharger.
1972 Mk3 Mini 1000, 1150cc supercharged.
https://www.ausmini.com/forums/viewtopic.php?f=3&t=95872
PostPosted: Sun May 17, 2020 9:34 pm
Anyone have experiance with the MED ST2 Ultra Light Assembly?
£329.17 EXC VAT
Includes pressure plate, clutch plate and orange diaphragm, "for fast road and trackday Minis. Expertly assembled and balanced, ready to fit".
Users browsing this forum: 68+86auto and 107 guests
