It is currently Sat Jul 05, 2025 6:29 pm
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Fri Dec 08, 2006 3:11 pm
Miniless wrote:
Spaceboy wrote:
i agree, this pulsar dizzy thing needs to stop
Why does it need to stop?
Why cant people be free to make their own decisions?
Yeah I agree with that too (miniless). If you don't like the nissan conversion (which I know you don't Spaceboy as I've seen in other threads) then that's fair enough, but at some point you should give it a rest, let us more experimental people have fun with toys and stuff. Me myself, i'm very much into this, I got N15 pulsar alterntor, 85 dizzy which is going in soon, and a toyota (SC-12) supercharger in the shed awaiting a kit.
Thanks for bringing this to my knowledge, a greasing I shall go!
PostPosted: Fri Dec 08, 2006 3:51 pm
I've been running mine unmodified for over 2 years without a hitch or any detrimental effects to the engine and it starts first go every time and has knocked off every small at the last couple of dyno events too so it can't be all bad in my books.
PostPosted: Sun Dec 10, 2006 6:22 pm
czerial wrote:
never had any problems with points, or with my mini not running in the wet.
maybe all those out there complaining about points just need to learn how to change
them properly, it really is not that hard u know
You hit the nail on the head Chris . Ive never had any problems with the lucas dizzy . If the points are adjusted correctly and you use waterproofing , you won't ever have any problems .....Raced a speedway mini for 10 yrs and never had any problems with the lucas dizzy ...I think it all comes down to education , or should I say at the risk of offending some people ..... laziness
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Tue Dec 12, 2006 8:30 pm
This is the mod that GR has done - the hole is about 5mm in diameter above the grove he cut.
David L
 Post subject: dizzy
PostPosted: Tue Dec 12, 2006 8:59 pm
i agree pulsar dizzy is the way to go. had one for 3 yrs now not a problem. lucas dizzy on the other hand had the points changed a couple of times but still worked ok. when i used standard pulsar dizzy more power and better starting.
i like to drive on rails
PostPosted: Tue Dec 12, 2006 9:31 pm
Rain No Problems 8)
