It is currently Sun Jul 06, 2025 6:24 pm
 Post subject: HIF38 Issues
PostPosted: Sat Nov 25, 2006 11:09 am
Hi,
I have a HIF38 carb that was an eBay bargain. Now I'm finding out why it was a bargain! :?
1) Under the fload bowl cover there is nothing connecting the jet to the mixture screw. There is also no connection between the choke mechanism and jet at all. The minimania site mentions a bi-metal strip. Is this what connects to the jet? Does anyone have any pics of a HIF38 or HIF44 with the float cover removed?
2) The part of the throttle linkage where the cable connects is missing. Anybody have any pics of this part so I can copy?
3) Lastly, anybody have a knackered HIF38 or 44 I can raid for the missing parts to get mine working?
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Sat Nov 25, 2006 3:43 pm
Brett
Send me your email and I will email you exploded diagrams and photos of connections - I got one out of England and it need a reco kit through it.
Midel (the Australian SU agents, based in Sydney) are very familiar with the carby and have all the parts. A reco kit is in the order of $20-30 and not hard to fit out.
The major problem is that the choke is a twist design and separated by a couple of seals. These seals harden and crack with modern fuels and allow unmetred fuel into the engine.
My email is [email protected]
PostPosted: Sat Nov 25, 2006 3:44 pm
Brett
PostPosted: Sat Nov 25, 2006 5:31 pm
maybe this helps
http://www.burlen.co.uk/partList.aspx?pump=&carID=10473
Rover 214 atm ....
PostPosted: Sat Nov 25, 2006 6:53 pm
Thanks for the help guys.
Mike_Byron, sent you an e-mail.
KLAS, that does help somewhat. It looks like I am up for a rebuild kit and a Bi-Metal Assembly Kit at minimum. But I still can't figure out how the mixture screw raises or lowers the jet. The diagram doesn't show how it fits on.
Maybe when I order the parts arrive it will make more sense! :?
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Sat Nov 25, 2006 7:56 pm
the bi-metal looks like this
the big hole takes the jet, the small one at the rivets is where its fittet to the carb body and the slot is where the adjusting screw sits.
turning the adjuter in you "bend" the metal an it lowers the jet
Rover 214 atm ....
PostPosted: Sat Nov 25, 2006 8:05 pm
<CLANG> The penny drops in my head.
That makes sense now. I can see how it works. Thanks! :D
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
Users browsing this forum: No registered users and 30 guests
