It is currently Mon Jul 07, 2025 12:50 pm
PostPosted: Wed Nov 22, 2006 3:37 pm
Just curious. Ive been doing my 998 for ages (nothing to serious though, just a bore and cam) But I know of at least 2 other people going for high power 998s
at the moment.
Interesting, as I love 998s and good to see them getting some work :)
PostPosted: Wed Nov 22, 2006 7:10 pm
nope i only have 2 projects on the go atm :lol:
wanna buy my 40DCOE weber for your 998? special price for you Chris
michael
PostPosted: Wed Nov 22, 2006 7:38 pm
I do, but you knew that did u chris
Aaron
PostPosted: Wed Nov 22, 2006 7:53 pm
ausmini mod
ausmini mod
I am one of those 2 people arent I Chris (its an 1132 but the block says 998) ;)
PostPosted: Wed Nov 22, 2006 7:57 pm
I had a bored out 998 motor put in just over a month ago and has now just done a 1000ks.
It has been bored to 1030cc, balanced, 282 cam grind, duplex timing chain, Pulsar distributor, Gemini starter motor, electric fuel pump. The head is a 12G202 that has had a bit of work done to it.
It has extractors and 2" exhaust and at the moment running with a 1.5 SU but I am putting on a 1.75 SU in the next few days to see if that makes any improvement to the overall power of the car.
With the new motor the LS is a real fun car to drive now with enough power to pull away from the lights without bogging down and can sit quite nicely at 110Kph on the highway without running out of puff...
With the bigger motor, 8.4" discs and new suspension, the LS goes, handles and stops a whole lot better than the standard car it used to be..
PostPosted: Wed Nov 22, 2006 8:58 pm
Just a small tickle then, Chris?
PostPosted: Wed Nov 22, 2006 9:12 pm
i going to be gettin one done i got it all planned just need the main ingredent $$$$$$ :lol:
PostPosted: Wed Nov 22, 2006 9:15 pm
i'm boring mine out one revolution at a time.. :)
PostPosted: Thu Nov 23, 2006 8:14 am
well chris u no my 998 is the beastest of them all, i would like to go through the list of mods but well...............................i cant cause its sh!t slow!
Hi-Ho Silver LS1275
PostPosted: Thu Nov 23, 2006 9:07 am
Aaron and pete, you are indeed the two that i know of.
I love the small bores :)
I reckon at future dyno days, there should now be a seperate class in small bores between 998s and 1098s (of course it will also be dependant on the good nature of the competitos as sometimes the engine number lies :) :) )
PostPosted: Thu Nov 23, 2006 10:35 am
Does an 1100 count? Bits away everywhere at the moment getting reground, repaired and modified. When it all goes back together it will sport a 295 modified head; RE flat top pistons; RE13 cam RE modiefied Pulsar dizzy, duplex timing chain, twin 1 1/4" SU's, 3 into 1 manifold into RC40 exhaust and 3.44 diff. Booster on the brakes.
Graham Russell reakons it will put out 85hp with plenty of torque down low :mrgreen:
David L
PostPosted: Thu Nov 23, 2006 10:53 am
yup 1100 is a small bore, not quite as small as those fantastic 998s but sttill great.
good to hear ur going to the god of small bores to get it done!
PostPosted: Thu Nov 23, 2006 5:15 pm
Then there's Erin's car too - Elle - we've finished the engine.........998 bored out to 30 thou over. Does that count???
Hooroo
Rod Image
PostPosted: Thu Nov 23, 2006 9:37 pm
I have a burning ambition to "work" a little 998 and see how fast can get it spinnin!!!
Hey Smokie - coming to Mt Cooper this Sunday???
PostPosted: Thu Nov 23, 2006 10:02 pm
at the moment.
Pity its sold now but this is the 998 I'd love to have. http://www.ausmini.com/forums/viewtopic ... =turbo+998
67 Deluxe under going full resto
