It is currently Fri Jul 18, 2025 11:32 am
PostPosted: Thu Nov 16, 2006 7:25 am
fitting the rear bin is easy, so long as the panel you cut out is the proper size. when fitting it you just push with all your life and then it pops into place.
i wouldnt recomend mdf for anything, as soon as it get's wet...... yeah i know you can seal it but marine ply/ply wood is better for trimming in my opinion. i'll try and resize those pics today. and i'll get you guys more pics of the back end brb
PostPosted: Thu Nov 16, 2006 7:27 am
I thought the pics were pretty good size now actually , do the other bits you want to include in it and I'll package it up as a how to .
PostPosted: Thu Nov 16, 2006 7:55 am
ok here is a rear panel
getting the lines to match up is the key
here are the carpet sets from know auto carpets, i'll tell you how they turn out in a week and tell you if they are worth it or not, seem pretty good to begin with all the lumps and bumps are in place. i'll make a photo gallery for fitting them
Image :)
PostPosted: Thu Nov 16, 2006 9:21 am
well i gotta take my interior apart again cause the glue was crap and stopped working so ill try wid some 3mm and hopefully she should work!
Thanks for da photos
Hi-Ho Silver LS1275
