It is currently Mon Jul 07, 2025 2:16 am
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Sat Nov 11, 2006 9:46 pm
Yes run it in with castrol, that's fine. The point of using KMX is that it is nice and thin for running in, plus i will probably need to dump it after the dyno mainly for transportation purposes, and at $14 for 6L, it's unbeatable value!
Lillee - 1969 Morris Mini K
PostPosted: Sat Nov 11, 2006 11:08 pm
When Graham Russell runs his motors in, he spends time putting them under lots of varying loads..... he doesnt simply keep it at 3 grand for 20 minutes.
PostPosted: Sun Nov 12, 2006 5:54 am
Yep he varies it up to 50lb/ft torque load, before doing power runs.
PostPosted: Sun Nov 12, 2006 8:01 am
chong - I have a box trailer sitting here doing nothing if it helps, when the time comes to move your motor. Also have a ute, but the tray is a bit high to lift a motor from by hand (4x4 rodeo).
I find one of the front corners of the trailer works best, can be tied off in several directions and pulled tight into the corner.
KB
PostPosted: Sun Nov 12, 2006 8:14 am
Hey KB, MAaaaaaaaate thanks for the offer! I was really getting worried about how I was goint to move the blardy thing! :lol: I'll let you know
