It is currently Mon Jul 07, 2025 11:50 am
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2, 3  Next
PostPosted: Sat Nov 11, 2006 4:37 pm
ausmini mod
ausmini mod
Howdy,
Got these photos from Graham.
This motor has 165ft/lb of torque from 4200RPM
It increased to 178ft/lb @ 7000RPM and the correction factor was 1.029 (so 244HP!!)
There was a slight prroblem with a sticky solenoid... the solenoid sticking caused the boost to bump up to 21.8psi and it produced 186ft/lb before the throttle cable was released! Graham dumped the throttle cable.
Pics:
>>>>>>>REMOVED AT REQUEST OF OWNER<<<<<<<
Peter.[
PostPosted: Sat Nov 11, 2006 4:49 pm
is that yours pete ?
PostPosted: Sat Nov 11, 2006 4:51 pm
ausmini mod
ausmini mod
I wish.
This thing has custom injection, intakes, etc, etc... did I mention 244HP :) and 178ft/lb torque.
No, mine is beinig assembled at the moment... worked on it today but itll be a baby compared to this thing.
Peter.
PostPosted: Sat Nov 11, 2006 4:58 pm
Awesome!!
Yes, there is a mighty A series under there... 8)
PostPosted: Sat Nov 11, 2006 5:00 pm
its ok Peter.
It's not always good to be fast :P
PostPosted: Sat Nov 11, 2006 5:06 pm
ausmini mod
ausmini mod
Betty wrote:
its ok Peter.
PostPosted: Sat Nov 11, 2006 5:20 pm
Betty wrote:
its ok Peter.
Won't be very fast with that torque and an A-series box. :shock:
BL reckoned on 94 as the "warranty" limit for metro turbo, hench the electronic boost limiting.
Looks like an interesting set-up, go the A-series.
Daniel
PS - What correction factor was used? SAE?
PostPosted: Sat Nov 11, 2006 6:49 pm
woah :shock:
nice engine... so will that all fit in a roundie bay? :?
PostPosted: Sat Nov 11, 2006 6:51 pm
ausmini mod
ausmini mod
I think its a late model one... Zeemax kit... Doc?
Peter.
PostPosted: Sat Nov 11, 2006 6:54 pm
Graham said it's a Rover or UK shell with a Zeemax kit, so yeah it does.
A hole or 2 may be needed for intercooler etc but yes the turbo & plumbing fits up into a standard bay. No `turbo box' required. 8)
Some real work has gone into this puppy..... :shock:
PostPosted: Sat Nov 11, 2006 6:57 pm
nice :D
PostPosted: Sat Nov 11, 2006 7:14 pm
DOZ wrote:
Betty wrote:
its ok Peter.
Daniel
Well Warwick Agustin has campaigned a fast race Mini for many years with a Toyota 4-AGE? chain driving a Mini box, he duels with the VTEC Minis like Borg's out there and it doesn't shed boxes... :lol:
A 4 synchro Mini box will stand 180+ HP, for how long IS the question. This turbo beast is in a road car so probably won't get caned after the initial euphoria. 8)
The correction factor used is for air temp ( & maybe humidity?) and barometric pressure on the day. :wink:
Engines are run complete with exhaust system, but minus the alternator and fan. Tank cooling is used.
PostPosted: Sat Nov 11, 2006 8:57 pm
That is an intricate & well set up turbo.
Awesome figures, hope it justifies the dollars spent 8)
PostPosted: Sat Nov 11, 2006 8:59 pm
been wondering when that thing was going on the dyno, its been sitting there for ages.
Warwick broke a drive shaft at the last meeting at Wakefield. it lasted 15 years, and was a modified Morris 1100 item. That is the first breakage that he has had in 15 years in the drive train. mind you it has a holinger straight cut gearset in it. i remember him getting real excited when it arrived at his workshop during the build of that little beast.
michael
PostPosted: Sat Nov 11, 2006 9:00 pm
Bloody hell. Thats alot
