It is currently Sun Jul 06, 2025 9:01 am
PostPosted: Fri Nov 10, 2006 3:23 pm
Hi all
Anyone got any tips for running in an engine on a dyno?
Seen this site that gives one way
http://www.mototuneusa.com/break_in_secrets.htm
PostPosted: Fri Nov 10, 2006 3:40 pm
yeah, we talked about it awhile back with that link
PostPosted: Fri Nov 10, 2006 4:16 pm
Yes, start her up, run for 20 mins at 3000rpm to bed in the cam and lifters. Allow to cool. Start up, warm up, then rev 5-6 times at full trottle to around 4-5000rpm.
That's it. you can run as many times as you like to whatever rev you want. It also helps to have an gas analyser to check the mixtures
Lillee - 1969 Morris Mini K
PostPosted: Fri Nov 10, 2006 6:22 pm
OK for a racer maybe...
Chong, remind me to relate to you a horror story about a partial piston seizure in a certain 1310 at 750 miles from rebuild.... :lol:
I think if you want it to last, a little more running in than 20 mins, at varying loads is required. :wink:
PostPosted: Fri Nov 10, 2006 6:25 pm
What is your suggestion for a dyno doc?
PostPosted: Fri Nov 10, 2006 9:20 pm
Well mine has fanged to 6000rpm about 30 times on the dyno now... so I don't see how this could happen?
PostPosted: Fri Nov 10, 2006 9:34 pm
Use a good mineral run in oil. Graham Russell swears by KMX (Kmart's own brand) and has run in everything from minis to V8's and formula junior motors with no problems at all.
If done properly on a dyno and setup correctly, it should be fine. If it is a standard road going engine, just take it easy and drive it normally for a few 1000 kms. I will drive normally from day 1
PostPosted: Fri Nov 10, 2006 9:40 pm
What's suggested is OK, my point above is if you want it to live long and happy, run it in a bit more when in the car... :wink:
after 600-800 miles with varying loads it should be free and sweet. :D
PostPosted: Fri Nov 10, 2006 10:29 pm
Or do like me, at 100 kms drive to Hay! :lol: - and back! Whilst slowly increasing speeds from 80ish to 110 by the time you get there, 110kph may be a bit high for a new engine. I don't know but I was worried about revving my girl for long epriods, now she is right. Great way to run a car in I reckon!
PostPosted: Sat Nov 11, 2006 10:24 am
Your advice then is to use a mineral oil (K-Mart KMX)for running in and not a synthetic oil such as Castrol Edge Sport 20W-50?
PostPosted: Sat Nov 11, 2006 1:19 pm
Yep run in with a straight 20W/50- The KMX is OK, so is Valvoline SF 20W/50.
Dump it and the filter at 200-300 miles and refill with oil of your choice.
I used the Valvoline for the 1st 1000 miles then went to the Castrol Edge Sport 25W/50. (was called Formula R 25W/50)
BTW this one is NOT a synthetic like all the other Edge ones. :wink:
PostPosted: Sat Nov 11, 2006 4:57 pm
ausmini mod
ausmini mod
Graham uses the KMX oil in all his cars (not just his minis)!
And he does NOT use it for running in only.
The Castrol Edge Sport is probably the best, but you cant go past the Kmart stuff either.
DONT run synthetic... its not friendly to Mini engines!
Peter.
PostPosted: Sat Nov 11, 2006 6:14 pm
I have loaded it up with the castrol edge sport 20w-50 prior to posting. Would you keep that oil in it for running in ?
What are the critical elements for running in on a dyno? Is Chongs method acceptable?
PostPosted: Sat Nov 11, 2006 6:40 pm
Edge Sport will be OK.
But I'd dump it & filter after a few hundred miles, as suggested and refill.
Yes Chong's (ie Graham Russell's) dyno running in method is OK.
Be aware that many modern electric `rolling road' dynos are NOT suitable for constant load, ie running in a motor. That said, an A series under part load represents a puny load to it.... so maybe OK. :wink:
ps. Graham's is an engine dyno, a different kettle of fish- they are a water brake.
<edit> for clarity
Last edited by drmini in aust on Sat Nov 11, 2006 6:56 pm, edited 1 time in total.
PostPosted: Sat Nov 11, 2006 6:47 pm
ausmini mod
ausmini mod
I would have to say Yes to both questions.
The oil is fine for running in and later (but as Doc and others say, replace oil and oil filter soon (cause its a new motor)
Graham has been running in motors this way for years... I dont see any prob... call him and talk to him about running yours in and see what he says.
Peter.
