It is currently Mon Jun 30, 2025 5:34 pm
Post new topic Reply to topic  [ 1054 posts ]  Go to page Previous  1 ... 24, 25, 26, 27, 28, 29, 30 ... 71  Next
PostPosted: Thu Nov 02, 2006 9:17 pm
Speak of the devil..haha it's pretty symbolic then...like car, like owner :lol:
PostPosted: Thu Nov 02, 2006 9:24 pm
i reckon a thai would charge less than the chinese
as emmeline would say:
[emme say something]
Inconspicuously Conspicuous
PostPosted: Thu Nov 02, 2006 9:28 pm
two dolla suckie sucki?
fie dolla **** ****?
PostPosted: Thu Nov 02, 2006 9:31 pm
how much for a massage with a happy ending?
PostPosted: Thu Nov 02, 2006 9:32 pm
you mean rub-and-tug ? :lol:
PostPosted: Thu Nov 02, 2006 9:39 pm
PM Sent. :P
PostPosted: Thu Nov 02, 2006 9:47 pm
hahha ur all nuts..
looking good josh.. pity about the big cut.. maybe try evening it up on the other side?
PostPosted: Thu Nov 02, 2006 9:48 pm
cheers, hey that's actually not such a bad idea?
PostPosted: Thu Nov 02, 2006 9:59 pm
but if your right arm got amputated, would you cut off your left to even it out?
try fix it! :D
PostPosted: Thu Nov 02, 2006 11:27 pm
$66 bucks for half an hour, for a pro rub/tug session... though, i hear they're only 15 bucks from the chicks at the skatepark... bargain. :shock:
eww... cant believe an engine conversion thread has turned into smut :oops:
:P
PostPosted: Fri Nov 03, 2006 5:58 am
i like emmelines prices better :lol:
PostPosted: Fri Nov 03, 2006 4:31 pm
space boy youre just no fun
you just dont know what kinda chickers youll find at the skate park...
PostPosted: Fri Nov 03, 2006 6:02 pm
BUT LIKE YER BUT NO BUT YER BUT LIKE WAT EVAR :lol:
PostPosted: Thu Nov 09, 2006 9:41 pm
Ok, little update..
Brake lines are done 8)
Master cylinder all mounted. Had to take a chunk out of the inlet. Nice fit.
The core you see in these pics is for the barrel, it will most likely go under the guard. Still waiting on the main core for the engine radiator which will sit at the front.
Alternator is also mounted.
PostPosted: Thu Nov 09, 2006 9:44 pm
Excellent. Where has the proportioning valve gone?
Subtle exclusion - you've bolted a great big fekin snail in front of zee motor?
