It is currently Sun Jul 06, 2025 4:41 am
Post new topic Reply to topic  [ 119 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
PostPosted: Sun Oct 29, 2006 8:46 pm
nice engine, wish mine was that clean lol, but yea i love drivin round the streets wit the accelleration, but not like it beats too many cars off the line lol. how much would it be to get that diff that you have?? coz i recently have been doin lotsa higway drivin n soon to be job will require higway drivin......been usin my girfriend's car as i thought that rpm would be hurtin the engine over long period of times....but yea how much to get that diff?
rodney
1992 Toyota Starlet GT EP82
PostPosted: Sun Oct 29, 2006 8:55 pm
does'nt really cost much for the 2.7 ratio but its hard to find one and putting it in is a bugger. there is a bit of machining to do as well so installing would be pricey. its a engine out job
while mine was out i put a new cross pin diff in. its all worth it though and it really doesnt affect takeoff that much, its a bit easier to control wheel spin lol :twisted: :twisted: :twisted: :P
i like to drive on rails
PostPosted: Sun Oct 29, 2006 9:01 pm
yes wheelspin we dont want that do we :wink: i'll talk to my mechanic aka my mum's boyfriend which runs a workshop and see what he can do......dont really fancy takin the engine out again :shock: it was bad enough the first time wen rebuildin the engine n gearbox to have the mini off the road. but yea approx how much did u pay?? jus for arguement sake.
Rodney
PostPosted: Sun Oct 29, 2006 9:04 pm
i paid 200 for the ratio but have seen them cheaper lately and i put it in myself. pulled the motor out after work on a friday and had it back in sunday arvo.
PostPosted: Sun Oct 29, 2006 9:20 pm
Firstly where do you live in AUS? i live in brissy, where did u get ur diff from n what are the detailed specs on this diff that u have, its sounding pretty good n would benefit from it a fair bit. so yer that would be awesome. Also if anyone else has got any ideas of where i can get a diff of this type.
cheers,
Rodney
PostPosted: Sun Oct 29, 2006 9:26 pm
well the diff is from minisport1275 i got it of ebay they have a ebay store and the diff ratio i got from a guy in america. ur best bet is just looking through the pommy and the american ebay sites. i live in coffs harbour, nsw
PostPosted: Sun Oct 29, 2006 9:28 pm
so can i use my existing diff and change jus change the diff ratio part of it?? sorry im gettin a bit confused.....
rodney
PostPosted: Sun Oct 29, 2006 9:30 pm
yer u can use ur old diff.
you just want to get a 2.7crown wheel and pinion and then ur in business :P :P
PostPosted: Sun Oct 29, 2006 9:34 pm
Thanx heaps, now its the difficult task of tryin to find it :(
How hard is it to put it in?
Rodney
PostPosted: Sun Oct 29, 2006 9:49 pm
well its not the easiest of jobs you have to pull the motor and box out, u dont have to split the box and motor but u will need a really long socket to get the pinion out if u do it without spliting the motor and box.
u get to the nut that holds the pinion on by taking the speedo drive housing cover off, once u
have that of u have to take the bearing retainer out and machine it so it fit over the 2.7 pinion
(as it is bigger that the 3.44 pinion) ant the re-assemble) easy done. hope this helps
PostPosted: Sun Oct 29, 2006 9:54 pm
thanx for all ur help, sounds like a future plan....if u happen to come across a 2.7 crown and pinion feel free to contact me. thanx
Rodney aka >Rude<
PostPosted: Mon Oct 30, 2006 7:23 am
>Rude< wrote:
is it hell slow coz thats something that i dont really want, the majority of my drivin is street cruizin (60-80km/h)
i dont think a 2.76 is good for what you describe.
PostPosted: Mon Oct 30, 2006 7:00 pm
3.44 with a 1275 is a good even combo. 100 k's at bit under under 4000 rpm, which is fine. It's certainly not too high for cruising on a long trip. Hay to adelaide at 110? Not a problem! For 1100 I reckon 3.44 would also be fine with the torque and all. A stock 998 or 850 I dunno, I've never driven one! :lol: But for those, I'd go 3.76, just my opinion tho. About 3.44, My cars got plenty of go, 3.44 is great! Only if you have normal gearbox (99.99% chance you do) if you got close ratio, 1st gear will be very long! But otherwise just go 3.44
PostPosted: Tue Nov 14, 2006 8:24 pm
When I upgraded my Mini SS from a 998 to 1100 I had a 2.9 diff installed. From memory that required a little grinding for the crown wheel to fit where the 3.44 item had been. The motor had a 12G295 head with rimflow style valves and a 1.5 SU on a metro water-heated manifold. Not a real hotty, but more power than standard. Anyway the higher gearing made it just magic for long distance driving and the car was also a lot quieter. Not something I'd do on a race car, but I'd definitely recommend that combination on a road car.
One thing to point out is that the 20% change in gearing makes your speedo awfully innacurate. I found that the Marina used the same gauges as the Clubman, but had a 200kmh top speed in place of the 160kmh Mini version. I grabbed one of these from Pick-A-Part and was able to simply swap the face plates over to give a nearly perfect match. Certainly close enough to mid 1970's speedo tolerances.
PostPosted: Tue Nov 14, 2006 9:17 pm
4000 rpm for that long cant be good for a mini engine surely, my 1100 is really working at that many revs, do you really think it would last like thaT?
Potato
