It is currently Sat Jun 21, 2025 7:46 am
PostPosted: Thu Apr 15, 2004 2:39 am
I have installed my H4 headlight conversion, with the parkers in the headlight, so now I am looking to change my Morris front indicators to orange globe, however these globes have a single filament ( ONE contact on the base ) and are not compatable with the Morris globe socket (offset pins aswell).
I have no intention of painting the normal clear globes (dodgey), or fitting Rover indicators cos i want to keep the Morris lense.
Is there another model of morris that has the same indicator assembly to suit a single filament globe??? Or am i just wasting my time?
 Post subject: globes
PostPosted: Thu Apr 15, 2004 8:36 am
it may be dodgey but painting the globes is cheap and it dose the job....but i think you can get orange mini indecater globes from huddersfield spares in uk go to mini wold book issue feb 2004 page towards back of book left hand side down the bottom...also you may want to try minimainia.com as they have heaps of stuff to like this...
PostPosted: Thu Apr 15, 2004 11:05 am
Have your tried LED orange globes from autobarn. I have them on my car but not sure of what type. They have various types so they might have yours.
mutant mini 1380cc '73 UK imp-Chroma Lusion-leather interior-8 x 300W Diamond Audio Dual Voice Coil 8" subs, Phoenix Gold 4 chnl amp, Pioneer 7550 DVD, 2x Phoenix Gold A1.800d MonoBlock Amp, Focal Utopia splits, 14" chrome rims 195/40/14 tyres
PostPosted: Thu Apr 15, 2004 7:41 pm
i was just gonna recomend these :D also u could be dodgy and grind 1 of the locating pins off the globes ( i did this and seems to work fine ) when i put clear lenses on my clubman
lookin for another clubby
PostPosted: Thu Apr 15, 2004 8:17 pm
Try giving Craig a call at Newport Motors in Royal Park hes usually the guy i call on for mini type "rare spares".
12 Months ?????????????
PostPosted: Fri Apr 16, 2004 12:50 am
I already have some spare orange globes here, and i AM going to file one of the side pins off, but i was hoping that i could get a proper socket and base for the orange globe - due to the original base (the plate with the spring behind it) having 2 electrical contacts....
i had a good think about it at work tonight..... maybe i'll just use a large amount of solder across the 2 contacts, making 1 big contact, so that the globe will connect properly.....
Yeah, LED's are a good idea, but a little too hi-tech for the 850's setup.... and i've found that LED's can only really be seen when you stand directly infront of em... (i should know - i've used TONS in the mazda...)
PostPosted: Fri Apr 16, 2004 5:21 pm
yrh these leds are designed as indicaor globes and are mulit angled tho , wat u think ?
PostPosted: Sun Apr 18, 2004 4:16 am
multi angled - meaning each LED in the socket aims in a different direction perhaps..... their beam is determined by the radius on the end of the diode, and dont have the ambient capability of a filament globe...... unless you've found some CrAzY globes i've never seen before (it is possible)
either way, i still need to do the single contact base, after that i'll play with different globes...
PostPosted: Mon Apr 19, 2004 10:24 am
Try this website:
http://www.superbrightleds.com
I know someone who has actually used these in his clear lenses. You have the choice of Wide Viewing Angle LEDS.
PostPosted: Mon Apr 19, 2004 11:30 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
just steal the tail lights of a semi's trailer
makka
PostPosted: Wed Apr 21, 2004 12:31 am
forget the trucks, i wanna knock off an ambo..... those strobe kits are WAY cool
