It is currently Sat Jun 21, 2025 1:04 am
Post new topic Reply to topic  [ 360 posts ]  Go to page 1, 2, 3, 4, 5 ... 24  Next
PostPosted: Fri Sep 15, 2006 11:25 pm
Hi there people,
Firstly, I hope nobody minds me chipping in with my Morris 1100 build up. I know its not a mini, buts its very closely related.
I am also going down the road of the Starlet engine transplant however my approach will be somewhat different to omst of the starlet builds in minis. I plan to use the starlet drivetrain complete with struts and brakes and everything, in the process ditching the hydrolastic, widening the track front and read and incorprating the starlet coilovers on the rear. Mine will also be a bit of a budget build, so I'll be using every last nut and bolt from my halfcut if I can, even the aircon if I can get it to work.
Anyway, so far I have partially stripped my halfcut and pulled the engine from the victim. Once I get the toyota motor out I plan to make a jig to transfer the mounting points to the 1100 then build a subframe to pick them all up and bolt to the car. I'll update progress when it happens.
http://www.counterfeitimage.com/morris/ ... Engine.jpg
For now heres a pic of the latest development, the hole I have to fill...
Madmorrie
PostPosted: Sat Sep 16, 2006 8:44 am
it looks like such a small hole.
Is the engine bay bigger or smaller.
About 3 months ago i needed nearly all the bits in your grab bag of parts for sale :)
PostPosted: Sat Sep 16, 2006 11:18 am
That will be such a sleeper 8)
PostPosted: Sat Sep 16, 2006 6:24 pm
Madmorrie,
Welcome to the brotherhood.
To quote a song - "The road is long, with many a winding turn...."
But, the end result is well worth it.
Good luck, and keep us posted.
Regards,
Tricky
PostPosted: Sat Sep 16, 2006 8:46 pm
This will be another interesting build.
Don't forget to post plenty of picks.
Dan
PostPosted: Sat Sep 16, 2006 9:26 pm
Floss, the engine bay is a good 150 to 200mm wider I reckon. You can see that the radiator surround it a bit deeper and the battery normally lives on the left between the side and the clutch housing.
I take it you dont need any mini bits any more. I still have them.
Everyone else, thanks for the kind words. Will post pics here when I can and also tryo to keep the site updated.
Madmorrie
PostPosted: Sat Sep 16, 2006 11:18 pm
awesome - I've been waiting for you to get this started since you first joined the forum - GO YOU GOOD THING!! :D
PostPosted: Sun Sep 17, 2006 7:59 pm
nah dont need the bits.
just thought it was funny, i have purchased nearly everything in the pile in the last few months :)
PostPosted: Sun Sep 17, 2006 8:17 pm
sweet man, keep us updated! i for one love morris 1100's because of the S that came with the motor that is now in my mini muahaha! :D
PostPosted: Mon Sep 18, 2006 8:20 am
I AGREE WITH YOU KEV
NOW THIS WILL BE THE SLEEPER OF ALL SLEEPERS...
FANTASTIC IDEA KEEP US POSTED
Baracade
PostPosted: Sun Oct 15, 2006 11:30 pm
Dropped engine into bay for first time today. it will fit ok, but still a looooong way to go...
http://www.counterfeitimage.com/morris/ ... ineIn1.jpg
Madmorrie
PostPosted: Mon Oct 23, 2006 10:14 pm
Hi Guys
Need supplies to create my jig so have turned my attention to trying to formulate a design for a suframe.
Bearing in mind I plan to use the struts and starlet suspension I have to translate the pickup points to the 1100. This is my first attempt at a workable design.
What do people reckon of these. A kind of superimposed top-view with perspective and a view from below with no perspective to clarify how it works underneath. I still need to do proper elevation style drawings.
Also I'm sure this has been asked before but are people just using mild steel for their frames?
Madmorrie
PostPosted: Mon Oct 23, 2006 10:32 pm
haha talk to user 92 in adelaide... he had one sweet easy way to put his in....
Baracade
PostPosted: Tue Oct 24, 2006 8:37 am
Very impressive Madmorrie.
Dan
PostPosted: Tue Oct 24, 2006 9:12 am
i'm glad someone's doing this to a morrie...
