I have a kit out of a 92-93 Rover ex Japan.
See pics:
(Warning - large pics!)
http://www.geocities.com/b_nicho/TravProj3.htm
I was saving this for my Traveller project, but now Im considering fitting it to my van for a while. I changed the gearbox in the van last weekend, so i relocated the heater hoses to the drivers side of the firewall (via holes in the fresh air blanking plate) and removed the heater core behind the grille in readyiness for the A/C. (I now have a reco Morris 1100 S radiator fitted, so cooling should not be a problem!)
I havent figured out all the brackets or the wiring yet.
Also same system fitted to a car in Jap wrecking yard:
http://www.geocities.com/b_nicho/mini_ac
You could probably replicate something similar.
- Toyota Tercels have a very similar sized condenser, you would just have to make up the brackets.
- Use compact A/C pump from something Japanese - Charade? Mount the a/c pump where the alternator is and mount the alternator where the air pump should go. You will need air pump double pulley, brakets and thermostat housing if not already fitted).
- Under dash evaporator unit can be pulled from any number of 60s-70's luxo barges - check BMW's, Mercs, Fords etc in your local boneyard.
- Use a dryer cannister and hoses off something common.
- Reroute heater hoses so you can use the original hose holes for the A/C hoses.
Hope this helps!
