It is currently Sun Jul 06, 2025 1:57 pm
PostPosted: Fri Oct 13, 2006 1:14 pm
outside the original cooper booster that is.
David L
PostPosted: Fri Oct 13, 2006 5:36 pm
I think a VH40 works, not sure of the boost ratio it's probably greater than a VH44.
PostPosted: Fri Oct 13, 2006 8:18 pm
yepp the VH 40 does work however it makes your braking very toey. I nearly went through the windshield with mine. It is now subsequently off and stored...lol
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Fri Oct 13, 2006 8:25 pm
There are some small boosters that were fitted to Jap cars in the late 60's. But i think the best option is a VH44. I know they fetch silly prices on ebay but you can pick them up from wreckers and swap-meets for much cheaper prices.
PostPosted: Fri Oct 13, 2006 8:29 pm
Resident Haemorrhoid
:? how do they hook up??
does it need a new master Cyl??
mtsmini wrote:
Tombo wrote:
PostPosted: Fri Oct 13, 2006 8:37 pm
They simply hook up to the pipe from the master cylinder to the brakes (you need to make up new pipes) And you need a vacuum hose from the inlet manifold. You use the original master cylinder.
PostPosted: Fri Oct 13, 2006 8:41 pm
there is a pipe from the MC to the booster and another from end of booster to the tee on the firewall.
Uses any 0.700" Mini MC.
PostPosted: Sat Oct 14, 2006 9:16 am
8)
thanks
mtsmini wrote:
Tombo wrote:
PostPosted: Sat Oct 28, 2006 10:27 am
In my travels I found out VH40 is for disc brakes and VH44 for drums.
The guy on ebay - Terry from Hyrdoboost 03 93904811 - has reconditioned ones in stock $200 something and $35 for the bracket to suit Mini
Question of the learned people - would you connect all 4 wheels to the booster or only the front wheels?
David L
PostPosted: Sat Oct 28, 2006 11:27 am
on a mini it's all 4 wheels, we have the limiting valve at the back to stop them locking up..... Cooper S's are set up with all 4 wheels
PostPosted: Sat Oct 28, 2006 7:51 pm
But if you have a tandem MC on a late Clubby just hook to the front circuit, it works fine.
