It is currently Fri Jun 27, 2025 2:46 am
Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Sep 14, 2006 11:35 pm
you guys are wrong about brickworx, the first listing was for a NON efi fuel tank, the more recent one is for an EFI fuel tank, thats why there was a price difference.
PostPosted: Fri Sep 15, 2006 6:01 pm
Madmorrie,
The batteries (there will be two) are Odyssey brand fully sealed gel cells and they will go in the bins next to the rear seats with lids on them.
One battery will just be for starting the engine, the other will be for powering the accesories etc, and they will be bridged when the engine is running by a solenoid so they both get charged.
Once the engine is off, they are isolated so the engine start battery will never get drained.
Regards,
Tricky
PostPosted: Fri Sep 15, 2006 6:31 pm
Madmorrie,
Sorry, the 2nd question.
The aussie starlet sender/pump unit I used for a couple of reasons:
1. Sender unit is calibrated to the Starlet gauge
2. Compact, in tank design which includes pre-filter, pump and sender unit all in one.
3. Fitted the dimesions (height) of the tank to a tee.
The pump, while too small to deliver to the fuel rail adeqautely at high rpm on the 4EFTE, will fill the surge tank just fine. The main delivery pump is a bosch 910 (450+hp rated).
Here is the pre-filter/sender/pick-up unit:
Cost from the wreckers - $65.00
Here is a shot of the surge tank and pump in position, 2 litre capacity.
Hope this helps and thanks for the kind words.
Regards,
Tricky
PostPosted: Fri Sep 15, 2006 7:48 pm
nice set up Archangel007
just wondering how you fix the sender/pump unit to the tank ?
57 Morris minor
88 Rover Mini
PostPosted: Sat Sep 16, 2006 3:17 am
With a mounting flange on the top of the tank
- I did the same with a Subaru pump for my moke
sorry about the pic size :oops:
PostPosted: Sat Sep 16, 2006 6:40 am
gzeVan,
The sender is fixed in the identical manner to AWDMoke.
There are 8 x machine thread screws that screw into the reinforcing rijng at the top of the tank. The ring is clearly visible in the photo of the tank.
A rubber gasket underneath seals the whole unit.
Regards,
Andrew
PostPosted: Sat Sep 16, 2006 8:21 am
love the concept guys and the use of the pump feeding the surge tank , im going to chase around for a sirion one today, but use it on the original tank.
My lift pump is one of those loud tickers and im fed up with the sound
57 Morris minor
88 Rover Mini
PostPosted: Sat Sep 16, 2006 1:21 pm
Thanks guys for the feedback
I was just looking through some old issues of my mini mags and seen a alloy tank in the wheel well similiar to archangle077 but round it was on a purple clubman sedan which is now a vtec i think if anyone remembers, so i might do that and just get a honda sender / pickup unit.
Just curious whats an alloy tank roughly cost to get made????
Thanks
Steven :wink:
Vtec Mini clubman. Commenced Jan 06.
Still Going June 07
http://s25.photobucket.com/albums/c71/sunburstvl/
PostPosted: Sat Sep 16, 2006 3:30 pm
Mr Enforcer quoted me just over 600 bucks for a rectangular cell (400x300x300) with sump, inlet, outlet, vent and filling holes. It's alot cheaper to get a premade one, they come in all sorts of sizes and materials. Your probably looking at $300 including sender and fittings.
PostPosted: Sat Sep 16, 2006 6:18 pm
Sunburst,
I took the view of getting a tank built to my own specification.
So, I took a detailed and dimensioned drawing to a local aluminium fab shop.
That way, they would build exactly what I wanted.
In my opinion, if you paid more than about $300-350 for this it would be too much.
This is a good way to shop around - you'll soon learn what constitutes a good price.
Tricky
PostPosted: Sat Sep 16, 2006 8:44 pm
Archange,
That setup will work a treat. Also understand why you set the system up like you did, twin exhaust, rusty boot floor.
Keep us posted.
Dan
PostPosted: Sun Sep 17, 2006 7:58 am
Thanks Dan,
Seriously thinking about starting a thread ala Dean's Bigbad so people can see what I have done and why I have done it.
Its been over a year now and I still havent got the thing on the road.
Anyway, if I can help solve other forumites problems or shed some light its all a good thing.
Thanks for the kind words, an I will keep you all posted.
Regards,
Tricky
PostPosted: Sun Sep 17, 2006 10:55 am
Hey Archange,
I think you should definitely start a thread on your build. It looks like you are doing some really good work, and have put loads of thought into it. I think a lot of people would agree with me. :D :D Start a thread
:lol: :lol:
Pierre
PostPosted: Sun Sep 17, 2006 12:57 pm
I agree ^^^, start a thread so we can monitir the progress.
Dan
PostPosted: Sun Sep 17, 2006 7:20 pm
So it is written, so let it be done!!
