It is currently Sat Jul 05, 2025 4:57 pm
 Post subject: under car striping
PostPosted: Sun Sep 10, 2006 10:20 pm
does anyone know how to set up a jig for a clubman to striping under the car, some photos wold help as well
PostPosted: Mon Sep 11, 2006 11:12 am
get some big tyres about four, i got some 17x9 ones from an old tyre yard, place them along the outer seams of the mini, tilt the mini up on its side. see threads in members pics section like weevans resto or nullabor express.
PostPosted: Mon Sep 11, 2006 12:39 pm
don't try and strip under a mini their's not enought roon for two and that means on fun :lol:
and a few conversions:
13B Extend in a 1600
PostPosted: Mon Sep 11, 2006 7:04 pm
I'll Agree I did my Van rear section with it in the Air and the front on the ground. It was a rite bugger of a job.
Roll it
But the Best way to clean it...Use a Heat Gun and Scraper then a couple of Twistlock Wire disc on a grinder.
Do wear protection for your eye's and a mask and open a the doors while use the the heat Gun :wink:
Lastley put some pic's up of your journey 8)
PostPosted: Mon Sep 11, 2006 11:18 pm
I have heard of acid dipping shells that cleans everything but isnt cheap, am i right?
Roundies Rule !!!
PostPosted: Tue Sep 12, 2006 8:04 am
yea also melts everything else..... only good idea if you strip everything completely - ec all wiring interior....... it will melt the sealer out of everthing and also the bog - makes a mess but the only way to do the job right the first time
on another not i sand blasted mine off - took a little bit of time and a couple boxes of beer but better than scraping it off
backyard performance............. Aint it the best
PostPosted: Tue Sep 12, 2006 9:51 am
At least you know there aren't any hidden rust, instead there will be holes
Roundies Rule !!!
PostPosted: Wed Sep 13, 2006 6:59 am
yea i would reccomend sandblasting tho - it still eats everything away but you dnt have to completely gut the body, gives you a fresh canvas to start from - but your panel beater bill will get bigger
PostPosted: Wed Sep 13, 2006 7:26 am
i would like to try and roll it so i can work on the side and not underneath plus its a bare shell so it doesnt need much to flip it over. i have got a sandblaster that i bought but its a crappy thing so i just use it on small things where i cant get into so ill have to got with the scraper.
PostPosted: Wed Sep 13, 2006 10:26 am
im having mine dry bead blasted... but then again im welding in a whole new floor front and back so it really doesnt matter if i blast holes :oops: :)
 Post subject: kero strip
PostPosted: Mon Sep 18, 2006 1:51 pm
Try soaking a rag with kero, place the rag on the body sealer then cover with glad wrap. If you leave this for 3-5 days it'll wipe straight off. (bugger of a thing to get to hang upside down, I used lots of magnets)
PostPosted: Wed Sep 20, 2006 9:14 pm
as mini k said get some old tyres and lay it over...
what i did was use a sharp scraper and cleaned up with turps The underbody deadner has a bitumen base which turps just eats. Its messy but...scraper + turps + elbow grease.
have fun though :wink:
Cheers Bryan
PostPosted: Thu Sep 21, 2006 9:59 am
im lucky i guess i have a forklift - lifted up high as and got in there with the sand blaster - did the whole body like that
PostPosted: Thu Sep 21, 2006 10:03 am
Just beware of sandblasting , stick a small vacuum tube into the sill vents to get it all out , we had dad's done a few years ago when it was restored , I've just had to cut one sill off and replace it due to rust . We found the sill packed with sand from sandblasting between the front guard and the jacking point . It was holding water and eating it's way out through the sill and inner sill .....
PostPosted: Fri Sep 22, 2006 9:01 am
yea went round it many times with an airline to blow it all out..... vacumed all the seams ect......
i had a problem with a customers truck that had been sandblasted and not cleaned right, was painting round the tool boxes in the back and blew up a sand storm!!! wasted hours of work and about 4 litres of paint lol
