It is currently Mon Jul 07, 2025 7:09 pm
 Post subject: superchargers vs turbo
PostPosted: Thu Aug 24, 2006 8:59 am
hi all, once i do rebuild my engine i would like 2 have a little extra power... im looking to find out wat would be better a turbo or a supercharger. wat does everyone think (taking into considerations of the cost)about this topic?
"Have you ever noticed? Anybody going slower than you is an idiot, and anyone going faster than you is a maniac."http://i129.photobucket.com/albums/p218/mini78s/theone.jpg
PostPosted: Thu Aug 24, 2006 9:08 am
supercharger....less mods, more response, better on fuel but not asmuch power. still good enough for hill climbs. depends on your driving style.
i wouldnt like boost coming on mid corner from a turbo.....and i like the response of a NA engine so for a quick fix i'd go the supercharger.
PostPosted: Thu Aug 24, 2006 9:56 am
supercharger = low rev fun
turbo = high rev fun...
re economy..
i'd say the turbo would be better on fuel... as you can keep it off boost....
supercharger is always boosting.... :twisted:
PostPosted: Thu Aug 24, 2006 10:04 am
Turbo has more wank factor I think.
:D
Does that help?
I think the supercharger is the way to go (thats what I'll do one day),
as the turbos are more likely to have overheating and reliability problems,
and usually you have to hack at the firewall (meaning engineers certificate needed).
PostPosted: Thu Aug 24, 2006 2:02 pm
i would also like 2 ask anyone that has had these mods..... what brand and where did u get them???? and cost????
PostPosted: Thu Aug 24, 2006 2:42 pm
search away
there's been many threads on it..
PostPosted: Thu Aug 24, 2006 8:57 pm
I've driven both types and what you choose to do depends on how you drive your car and were you drive your car, I prefer the turbo as I do a lot of highway driving and it gets really annoying with a supercharger on the highway as they constantly whine.
A supercharger will be a lot cheaper and easier to setup and maintain than a turbo and is a lot better down low in the rev range which is suited to heavy traffic and taking off at the lights, where a turbo is more suited to a long stretch where you let the engine rev right out.
PostPosted: Fri Aug 25, 2006 12:44 am
Not the SC12 :wink: Has an electronic clutch drive.... flick the switch to turn the boost on or off, or wire up a vacuum sensitive switch to engage boost at a preset amount of vacuum in the inlet manifold....
Turbo ALWAYS feels faster because it "winds up", where as a supercharger "drops off" as the revs increase
PostPosted: Fri Aug 25, 2006 8:49 am
Slow-Po
a la....
PostPosted: Fri Aug 25, 2006 10:38 am
It depends on the supercharger, an Eaton/Rootes type will drop of at revs whilst a scroll type like a Sprintex will keep pumping all the way to the redline.
Turbo produce more engine bay heat than a supercharger, and a Sprintex super is much cooler than an Eaton/Rootes.
Turbo produce as much initial lose in hp through backpressure as superchargers do off the crankshaft. The difference is that a turbo has to spin up whilst a supercharger is on (unless you clutch it).
With superchargers you have a choice of drive positions, crankshaft or flywheel whilst with a turbo you got one.
PostPosted: Sat Aug 26, 2006 12:53 am
Ah yes, forgot about those "other" ones :oops:
PostPosted: Sun Aug 27, 2006 8:09 pm
With my SC12 max boost is at max revs 13psi at 8000rpm so they don't drop off.
4efte powered Clubman
supercharged 998 race car
PostPosted: Sun Aug 27, 2006 8:18 pm
When I had my Supercharged MR2, the boost was most effective below 4000RPM. Anything above that and it wasnt much faster than a naturally aspirated car (unless it was going up a hill) . Having said that, it still did a flat 13 second quarter mile....... 8)
PostPosted: Mon Aug 28, 2006 8:58 am
i quite like the whine of mine, only upset set that i cant get it to go WAAAOOOOSSSHHHHH when i change gears turbo style BAHAHAHHA
PostPosted: Mon Aug 28, 2006 10:00 am
hey who said you cant get a lot of psi out of a blower, my mecha said that he had a commodore with 2 blowers that had a total at a max of 6750rpm, 11psi, mind you his sons skyline bov sounds like a gunshot,
