It is currently Tue Jul 08, 2025 8:26 am
 Post subject: bonnet lock downs
PostPosted: Mon Aug 21, 2006 6:03 pm
hey guys i would like to fit bonnet lock downs to the four corners of my bonnet so i can have a removeable bonnet so its easier to work on just wondering if anyone has done it before and how they did it what type of lock downs did you use. any pics would be great to.
Cheers Dan
PostPosted: Mon Aug 21, 2006 6:32 pm
You might think that it is easier to work on but in reality they are a pain in the arse. You end up chipping the paint off all the corners of the bonnet and when you are doing quick road testing you end up having to lift the whole bonnet off when you would normally just lift the front and give the dizzy a fiddle or the carby or whatever.
The old trick was to cut a slot in the bonnet hinge to make a hook so you could use the bonnet normally or you could lift the bonnet off just as quick as using pins.
A couple of problems with pins...
If they are made from aluminum they will break.
If they are made from die-cast they will break.
If they are made from steel they will rust. (Even when painted because they will wear the paint off where they rub in the holes)
Kids pinch the locking pins.
You forget the pins and your bonnet flies off.
You end up leaning on the pin while you are leaning over the back of the engine and you remove a testicle. 8)
PostPosted: Mon Aug 21, 2006 7:06 pm
:shock: yes, it just neded to be highlighted! :lol:
 Post subject: and.....
PostPosted: Mon Aug 21, 2006 7:26 pm
[quote="Morris 1100"]A couple of problems with pins...
Kids pinch your bonnet!
[/quote]
 Post subject: mm1275
PostPosted: Mon Aug 21, 2006 9:11 pm
This is what you are looking for mate, somthing like this.
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Mon Aug 21, 2006 9:18 pm
I did it for looks, and because i got pissed of when first re installing everything back into my car after painting that it would make life easier....NOT AT ALL! yes you get less back aches when working on your car, but for short fixes, like said above, igniton etc, hinges are great. When you do want to remove your bonnet, it's four nuts to undo, not hard at all. Now if it's for looks thats different cos it does look tough but yes, i'm waiting till my pins get stolen, cos they will. I only did two at the back tho, my front is still secured by normal release with safety catch. But it looks cool with only two at the back.
PostPosted: Tue Aug 22, 2006 5:59 pm
ok having a removeable bonnet sounds liike not a very good idea i mainly wanted to do it because i thought i would be easyer to work on and cause i can't find a bonnet latching mechanism anywhere.
Cheers Dan
PostPosted: Wed Aug 23, 2006 9:19 am
if you have a roundnose get some leather straps....if you have a clubman get some pins.
PostPosted: Wed Aug 23, 2006 1:47 pm
yeah i like the look of the black straps but will they pull the bonnet down hard enough to stop it from vibrating without the bonnet latch
Cheers Dan
PostPosted: Wed Aug 23, 2006 2:02 pm
Whats under the hood thats causing so much vibration?
Roundies Rule !!!
PostPosted: Wed Aug 23, 2006 2:18 pm
Bonnet straps are better then the latch.. mini bonnets have been known to fly off at high enough speeds.. hence the straps.
PostPosted: Wed Aug 23, 2006 2:21 pm
a big v8 8) na i wish i just thought the bonnet would vibrate cause theres no bonnet latch.
Cheers Dan
PostPosted: Wed Aug 23, 2006 2:52 pm
I have travelled from sydney to canberra and back in my hot breathing 1380cc with 4.11 ratio high reving motor and never had any problems, no straps, just the standard dog pin.
Roundies Rule !!!
PostPosted: Wed Aug 23, 2006 5:15 pm
i dont have the proper latch either, and ive been using a single leather strap for close to 4 years...take my car rallying all the time...as long as you fasten the strap properly im sure you'll be fine......it worked for the works mini rally cars.......
PostPosted: Wed Aug 23, 2006 9:38 pm
cool thats what ill do ill buy some strapes for it
cheers guys for your help
Cheers Dan
