It is currently Thu Jun 26, 2025 10:13 pm
Post new topic Reply to topic  [ 89 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Sun Jun 18, 2006 7:52 pm
You have done a top job. It looks like its come straight of the production line.
Thumbs up.
Dan
PostPosted: Sun Jun 18, 2006 8:26 pm
Your engineer would have to be happy to sign off on that.
It looks better than factory. Great work 8)
PostPosted: Mon Jun 19, 2006 12:35 pm
Yeah brilliant effort mate. That looks so neat and given the more compact motor getting the original rad in the front is equally brilliant. My original premise for the Starlie conversion was more about drivability rather than power (though that's addictive) so the Sirion conversion must be brilliant in that regard. A few tweeks and you'll be blowing the 1275's off the road. Also nothing wrong with sleeper :wink: .
 Post subject: the daihatsu
PostPosted: Thu Aug 10, 2006 2:39 pm
nice one paul
looks great under the bonnet mate
just need to do something about the rest of the beast
its great youve given an alternative to the starlet
im impressed
i might see it at panthers (when is that again)
peace out homie
tim ( troys mate )
sell 'em and by an MX5
 Post subject: Well Done
PostPosted: Thu Aug 10, 2006 6:22 pm
Great work mate....what I am really interested to hear about is how it handles :?: :!:
[color=blue]yes its a 3 banga was one of the most fuel effiecent motors in 2000 its only around 65hp standard but its 50kgs lighter than the 'a' series ,so it should move along nicley[/color]
With 50 Kilos less over the front wheels she must be a nice handler :?: :)
(PS the Italians used Dai three cylinder engines years ago....so the precedent has already been set :wink: )
PostPosted: Thu Aug 10, 2006 9:58 pm
Hey gYaTaH
Have had the car on the road for a while now and is well sorted
At first it was a bit hairy around corners after the CV and wheel bearings i thought where ok turned out to be stuffed and the noise comming from them was pretty scary and the new powerhouse made things worse :oops:
so after a new set of CV's and taper bearings it happy dives into corners and you can notice the extra weight off the front more so on quick tight turns :D
its just a bit to low it the moment thats the only downer it scrubs a bit on the flares on the tight ones
the Van is also getting a CT12 turbo for christmas ,which i have just cant afford to put on till then (respray is more important at the moment)
cheers Paul
57 Morris minor
88 Rover Mini
PostPosted: Sun Aug 13, 2006 9:16 am
great job looks like its meant to be there how does it go on fuel the starlet sucks it do you have twin tanks
PostPosted: Sun Aug 13, 2006 9:29 am
hey stabba
the van run's on the sniff of an oily rag
the motor from Daihatsu specs uses 3.9L per 100kms so in the van pulling just over 100kgs less weight should make it less again
have not run down a full tank yet to see, Im one of those $10 hear and there people :lol:
my tank im guessing is identical to yours do you know how much it holds in litres?
57 Morris minor
88 Rover Mini
PostPosted: Sun Aug 13, 2006 12:45 pm
Will it fit a roundy?
PostPosted: Sun Aug 13, 2006 3:22 pm
my bad i forgot your one was a van i got a stainless one a bit of a drop tank it holds about 28 29 litres your one good news for long drives i need a servo every 150 kilometers
PostPosted: Sun Aug 13, 2006 3:58 pm
yes willy it will fit in a round nose with a smaller radiator, i just went for an overkill one on mine
I almost got a round nose the other day and was going to swap everything over to it ,but it didnt go down to well with the wife
57 Morris minor
88 Rover Mini
PostPosted: Sun Aug 13, 2006 4:31 pm
Seems an excellent conversion for an everyday car.
Do you mind telling us what you paid from start to finish?
PostPosted: Sun Aug 13, 2006 6:50 pm
owes me about $4000 including the car but i did not have to pay for things like motor box computer radiator, wiring up
57 Morris minor
88 Rover Mini
PostPosted: Sun Aug 13, 2006 7:18 pm
The conversion will slowly pay itself off from buying petrol; versus fuel consumption of a 1275, I would imagine.
PostPosted: Tue Sep 26, 2006 10:02 pm
hi luv the conversion and am realy interested in doing something similar. what mods were donr to the front subframe?
cheers matt
i like to drive on rails
