It is currently Sun Jul 06, 2025 6:23 pm
 Post subject: 1275 how much oil?
PostPosted: Thu Aug 03, 2006 9:11 pm
Need to do an oil change and wanted to know how much oil will by baby need.
also what oil do you fellow ausminians recomend to use? :wink:
S.M.R
PostPosted: Thu Aug 03, 2006 9:25 pm
Castrol Formula R or now known as EDGE 25W50
Lillee - 1969 Morris Mini K
PostPosted: Thu Aug 03, 2006 10:04 pm
About 5L with the filter, a bit less without. :wink:
PostPosted: Thu Aug 03, 2006 10:51 pm
until it comes up to full on the dipstick heh :P
 Post subject: Re: 1275 how much oil?
PostPosted: Fri Aug 04, 2006 1:49 pm
most 20w50, cheaper stuff will be more suited to the loose tolerances of the mini engine than more expensive oils with additives or synthetics, change oil and filter frequently due to the trans sharing the same oil.
PostPosted: Fri Aug 04, 2006 2:54 pm
8)
PostPosted: Fri Aug 04, 2006 3:02 pm
unless your motor is fresh and or modded i wouldnt bother with expensive oil.
Users browsing this forum: No registered users and 32 guests
