miniboy1962 wrote:
I dont really like the look of the swirl of pipes - add too much weight and space, and i dont really want to space the grill, although that silver van you can hardly tell.
I don't think the look should come into it... they're designed that way for gas flow properties, not for the way they look - the extra 100 grams of weight you get in the extra tubing would no doubt be lost in performance with exhaust restriction if you went for a log...
the starlet turbo setup in a roundie only has the grille spaced because the turbo sits infront of the motor, by the looks you're planning on putting yours over the gearbox so you shouldn't have any space issues
here's how TurboOrangie has done his turbo GTi setup... infront of the motor
not that I know crap about turbos... but I've seen a few custom ones, and logs aren't the done thing
did I tell you that I won a
trophy?
