It is currently Sat Jul 05, 2025 7:13 pm
PostPosted: Sun Jun 18, 2006 8:23 pm
anything is better than the 2x 30 fuse box... I had the solidoid blow up behind my gauges and I was smoked out ofg my vehicle.
PostPosted: Wed Jun 21, 2006 2:30 pm
Ooooh, they have a "BLING" one on special at Jaycar:
http://www.jaycar.com.au/productView.asp?URL=index&ID=SZ2077&CATID=23&SUBCATID=552
for less than $35
PostPosted: Thu Jun 22, 2006 8:29 am
:shock: I like the look of that one 8)
PostPosted: Fri Jun 23, 2006 8:34 am
VERY YUMMY ok Zack get a hold of yourself... I think I might just have to go into Jaycar and enquire about it.
PostPosted: Fri Jun 23, 2006 6:48 pm
that particular one there is for audio systems - there are 2x4guage inputs into 4x8guage outputs (you connect up an earth to get a digital readout of the voltage in realtime)
your after one that takes blade fuses so that one is not the one your looking for but i have no doubt jaycar will have something for you
PostPosted: Sat Jun 24, 2006 9:10 am
ausmini mod
ausmini mod
I went into Jaycar too... wanted to buy it.
It acutally takes 1x 8gauge and splits into 4x 4guage ... also it takes 5g fuses not 3g
5g are the bigger fatter ones... not sure how easy to source when you need 'em
I think i'll g to Supercheap or Peps/Repco and find a fuse box with 2 circuits or 2 fuse boxes.
Peter.
PostPosted: Sat Jun 24, 2006 10:22 am
Yeah but I might be upgrading slightly on my stereo so I won't want it to be under nurished as for fuse box for the rest of my electrical stuff Im sure my trusty auto electrician can help me out.
PostPosted: Sat Jun 24, 2006 11:51 am
have a look at the link not sure of the prices but are available through repco
http://www.narva.com.au/Fuses_16.html
Jon
PostPosted: Sat Jun 24, 2006 12:25 pm
you've got it the wrong way round (4guage is thicker than 8guage)
quote from thier page -- > This block will accept 1 x 4 gauge cable in, running to 4 individually fused 8 gauge outputs.
i have this dist block myself and used it when it first came out in my corolla - there are actually 2 4guage inputs (one on the back and one on the side - but you would only use one at a time)
PostPosted: Sat Jun 24, 2006 1:59 pm
Jon
I have just used the 8 fuse Navara for the rewire of my mini. Mounted it in under the dash out of the weather :wink:
Minimad
You can take the boy out of the racer.........but not the racer out of the boy!
