It is currently Fri Jul 04, 2025 2:47 pm
PostPosted: Thu Jun 08, 2006 4:42 pm
Hi
Can someone help?
I am fitting a Smiths electrical temp gauge to an A+ 1275.
The gallery is approx 5/8.
Does anybody know the correct Tridon or VDO sender unit to use?
PostPosted: Thu Jun 08, 2006 5:52 pm
Should take the same sender unit as a standard clubman? GTR104 I think
PostPosted: Thu Jun 08, 2006 7:14 pm
Is that a tridon or VDO?
PostPosted: Thu Jun 08, 2006 8:01 pm
I don't think it's either, probably a Unipart item?
PostPosted: Thu Jun 08, 2006 9:33 pm
Don't forget that you need the regulator thingy to change the voltage from 12 to 10V, otherwise the gauge will read high
Minimad
You can take the boy out of the racer.........but not the racer out of the boy!
PostPosted: Thu Jun 08, 2006 10:03 pm
Minimad
Not all Smiths gauges were 10V, the common aftermarket ones were 12V. My bro' fitted them to his Imp, they read fine with 12V supply.
