AJ,
I must take issue with this heat dispersal (ie thermal conductivity) thing- aluminium has
inferior thermal conduction to copper, although it IS better than brass.
Modern cars use alloy because it's cheaper (for them) to make it. But they don't sell em cheap to us, when the plastic tanks crack, do they.....
Note all radiators in Oz Minis from Mini Deluxe/Cooper S on, had 16 gills (fins) /inch- the 850 before that was basically UK design and only had 12 gills/inch.
The 3 core UK made? radiator I purchased recently only has 12/inch. So next time, I'll recore an Oz one instead of buying imports.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
