It is currently Tue Jun 24, 2025 3:05 am
 Post subject: suzuki swift engine
PostPosted: Sun May 14, 2006 8:09 pm
ok folks...yay or nay
:) Eddy :)
PostPosted: Sun May 14, 2006 9:12 pm
Why not?
PostPosted: Mon May 15, 2006 12:14 am
easy peasy
http://www.ausmini.com/forums/viewtopic.php?t=15592
my swiftmini @ http://www.16vminiclub.com/forums/viewtopic.php?t=4888Image
 Post subject: Re: suzuki swift engine
PostPosted: Mon May 15, 2006 8:21 am
Which swift engine? whats it going in? what are you looking for?
1974 Moke - 998cc
PostPosted: Mon May 15, 2006 12:57 pm
If its not a G13b (Gti) do not bother 8)
PostPosted: Mon May 15, 2006 5:13 pm
ok i was just asked in general so i thought ide ask you guys
:) Eddy :)
PostPosted: Tue May 16, 2006 10:53 am
The G16B is not a bad performer and no bigger than a G13 single cam engine
Tricky
PostPosted: Tue May 16, 2006 11:18 am
I believe the G16b block is an inch taller and uses a non-forged steel crank.
PostPosted: Tue May 16, 2006 11:21 am
hope so or i am waisting a lot of time and money :wink:
PostPosted: Tue May 16, 2006 4:25 pm
Hi Marc,
Unless you are going to wring its neck past about 8500rpm, then a cast crank is just fine.
I actually met the two brothers (they own Alstonville Wreckers) who did Cons original conversion (G13B Twin Cam) on his Burgundy Mini (now sold) and they said that if they were doing the conversion again, they would choose the G16B over the G13B everytime.
Apparently, same power output, same weight, more torque and a lot less hassle. The motor is a SOHC 16 valve engine and breaths just fine.
Regards,
Tricky
PostPosted: Tue May 16, 2006 5:44 pm
and if you havent seen cons mini, you should definately search for it.
umm if you check out redlinegti.com you will see that there aint a whole lot of difference between the two.
i mean the most powerful N/A is a 1.3L so you never can tell.
if your after torque then the 1.6 bottom end is a great way to go. although according to half the knowledgable guys on redline its a waste of time. there arent that many out there, so if your gunna do it you will be a pioneer.
either way you go, to get alot of horse power from an N/A swift motor, requires cash and knowledge. as it does with most other motors.
really the choice is up to you.
Torque Steer is a very evil thing. Fun..... but evil.
West Aussie Mini Boys Represent...!!!
PostPosted: Tue May 16, 2006 10:34 pm
yeah i have a gti engine sitting around waiting patiently to get some use i think it should be ok
it should have enough power for me be a smooth ride
fuel usage should be good too
one day :roll: i will get round to it
PostPosted: Wed May 17, 2006 9:57 am
the GTI engine will be a great conversion, so if ya can get it done I advise it.
as for the power stakes, it pushes and almost 800kg car, maybe bit more, to a 16 second quarter mile as stock. so pushing along a mini it has no trouble.
as for the fuel consumption. I have been using mine as a daily to and from work.
i filled up the long range tank, i think about 33 litres. and i got 627km before i had to fill up again. that also included the mini night at the drags. so five runs down the strip and hour drive to and from the plex. and i have a highly modified motor, so standard should be even better.
hope you decide to go ahead with it.
good luck
Heath
PostPosted: Thu May 18, 2006 10:29 pm
hi eddie, if you dicide to do it ,i have a engine ,gearbox pretty much a frontcut for sale ,im in toronto nsw 49593098,thanks ken
current newcastle area motorsport khanacross and dirtspeed outright champion
PostPosted: Sat May 20, 2006 7:25 am
The 1.6 has more torque hands down. They are a little taller because of the longer stroke, but with the transmission being on the side rather than underneath like the a-series it may not be a problem. Inlet manifold is pretty big though so this may cause clearance problems. The SOHC head flows very well for a stock head. Crank and rods are not as strong as the GTi though.
I am into Suzuki 4x4s and these two engines are tossed around as swap options. In a lighter car like the Mini the GTi would be better than it is pushing along the extra weight of the 4x4, but the extra torque of the 1600 would make it a lot more drivable I think.
