It is currently Sat Jul 05, 2025 12:17 am
PostPosted: Sat May 13, 2006 6:16 pm
Hi All
Just curious of how you best organise all of the nuts and bolts when pulling a motor down....
TK told me to bag everything and label into snap lock bags.
Anyone got any other ideas? I do not have a lot of space and no real permanent place to keep everything layed out.
Cheers Gerard
PostPosted: Sat May 13, 2006 7:57 pm
Mate the best thing to use is ice cream containers as you can label the lids.
To keep your pushrods and head studs cut out cardboard and poke holes in it pushing them in labeling where they come from .
PostPosted: Sat May 13, 2006 8:10 pm
Chinese food containers are great. You can write on the lids with Nikko and see inside so you're not looking though assorted containers.
Buying 100 snap-lock "Deal Bags" is fun. The supermarket 17 year old check-out kid wants your phone number so he can score weed and the security guard glares and fakes calling the cops.
M
PostPosted: Sat May 13, 2006 8:45 pm
LMFAO - man that is good
guys that is helping so much
anyone got any other ideas - there must be millions of ideas :D :D
PostPosted: Sat May 13, 2006 8:54 pm
I went to the $2 shop and got 100 ring folder plastic A4 sleves for [you guessed it] $2
Get a milk crate
Bag assorted bits as they come off and place the bag in the crate
The trick is to leave the bags alone - resist all temptation to go searching through them later.
For reassembly - not only are all the parts together, labled, and complete - but ther are in the reverse order that you took them off, so the contents of the top bag is the first thing you need to put back on. :idea:
Cheers Dat
PostPosted: Sat May 13, 2006 9:01 pm
I use Coke bottles ....
Push the nuts and bolts into them as you pull the stuff apart ...
1/2 fill with Kero / Diesel / degreaser - Shake regularly
empty out degreaser in environmentally aware method ....
1/2 fill bottle with hot water, empty, repeat until water runs clean
Cup top off bottle and use the now very clean nuts and bolts !
J
PostPosted: Sat May 13, 2006 9:07 pm
WhoDat I like your thinking.... reverse order
Kazjim I like the idea to clean - but my problem is i would not know where each one goes back too
cheers Gerard - this is some great stuff guys
PostPosted: Sat May 13, 2006 9:08 pm
also need ideas for some of the bigger stuff too - conrods and pushrods etc.... The cardboard is a good idea
PostPosted: Sat May 13, 2006 10:52 pm
I use the ZipLock Method but I like your idea James
Wash in Coke bottel then Bag them clean with a little WD :wink:
Large Parts like Crank, Cam and Rods, Once again Wd but in and old pair of Jeans Legs or Business Shirt Sleave. I guess you could do the same with the block also :idea:
PostPosted: Sun May 14, 2006 2:34 am
Too late, all my bits are in one big black Mitsubishi production line parts box :D
Steve is building the motor anyway, i'll let him sort it out and then see if there are any bolts left over afterwards :shock: :lol:
Plus, some bolts/nuts/washers WILL need replacing, and this is the time to be doing it...
PostPosted: Sun May 14, 2006 12:40 pm
I like to grab the digital and take THOUSANDS of snaps if I'm not sure of how things go back together., especially cable runs and other small crap things. That way you don't spend your day making small drawings.
PostPosted: Sun May 14, 2006 4:19 pm
thas a good idea
PostPosted: Sun May 14, 2006 4:52 pm
That is the best idea! :lol: And if you are not sure you can post a photo on the forum and get help. :wink:
PostPosted: Sun May 14, 2006 5:46 pm
fella that is even betterer.......idea
PostPosted: Sun May 14, 2006 6:04 pm
if you have lot's of bench space like me. I got rolls of butchers paper and I drop them in piles then write on the paper what they are and any notes I can think of to put them back togeter.
when pulling wires and hoses off if it looks complicated then I grab some thin masking tape and the same pen and write where they go. if their's too many I just resort to mumbera and letters in both ends.
obviously wires and vac/heater hoses aren't going to kill you if it's a a series....
This method only pays if you have a BIG bench space and it's not going to be apart for too long.
abviously I use envelopes for longer periods of time.
Idon't like the glad bags idea as I was forever letting the texta's dry out and eventually can't find one that works!!!! bit of a bummer.... pens don't dry out
obviously envelopes like to tear and their's their downside. Just putting it out there for ya you might not have enough bench space though???
and a few conversions:
13B Extend in a 1600
