It is currently Mon Jul 07, 2025 3:27 am
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: Power Tuning the 998
PostPosted: Fri Apr 28, 2006 1:57 pm
I thought i might start one for the 998 too.
All the best advice and tips and tricks for getting the best from the 1 litre screamer...
(hopefully these could be stickies...) hint hint..
PostPosted: Fri Apr 28, 2006 8:43 pm
put a 1098 Crank in it and its a 1098 Motor with a 998 engine number 8)
PostPosted: Fri Apr 28, 2006 9:32 pm
I hope i got this right ..... but don't you need 1098 pistons also ????
Is there anything else beside the crank and the pistons that you need to turn a 998 into a 1098?
Cheers Gerard
PostPosted: Sat Apr 29, 2006 1:52 am
the 998 crank is BETTER than an 1100 crank :roll:
PostPosted: Sat Apr 29, 2006 8:22 am
Hmmm I've seen both sorts break, so why not use the 1100 one and get the extra 100+cc.. 8)
For a ROAD car, there's no substitute for cubic inches...:wink:
PostPosted: Sat Apr 29, 2006 11:00 am
Yes but, if you put the 1098 crank and pistons in the 998 block, well, you'd have to go look at the 'Power Tuning the 1098' thread now wouldn't you??
I've personally seen 1098s stand up to a lot of abuse, even stock ones. The problem I usually see isn't crank wear but the bores wear more due to the long stroke. No matter how much you adjust the tappets you can't get rid of piston slap :wink:
PostPosted: Tue May 02, 2006 7:30 am
cheers guys
PostPosted: Tue May 02, 2006 12:59 pm
Get onto any British mini forum or pick up a magazine.
They don't have 1100 engines there, so it's powertuned 998s all the way. :D
PostPosted: Tue May 02, 2006 1:07 pm
cam head(late type, hardend seats 28cc???) plus mr megasquirt plus mr garrett.....
PostPosted: Tue May 02, 2006 2:35 pm
Peter Garrett?
:lol:
PostPosted: Tue May 02, 2006 2:37 pm
:lol:
FUNNY.
Santo
"The Lone Ranger"
HI-HO Silver......AWAAAAAY!
PostPosted: Tue May 02, 2006 3:34 pm
Nice willy :lol:
Mr Kompresorius Garett
[/img]
PostPosted: Tue May 02, 2006 9:13 pm
What has adjusting the tappets got to do with piston slap?
I thought piston slap was the uneven wear in the bore causing excess movement of the piston inside the bore. :?
PostPosted: Wed May 03, 2006 4:52 am
loose tappets make a similar noise :lol:
PostPosted: Fri May 05, 2006 10:11 am
What sort of extractors would u guys recommend for a 998, i just bought one and im looking to give it a lil more kick, but trying not to swap cranks or stuff like that over? What will adding maybe 3:1 extractors and a new exhaust do for it, would it be worth it? Apart from switching cranks over, are there any other mods you would recommened, im currently running a single SU carby, and am pretty sure the rest is still standard!
Hi-Ho Silver LS1275
