It is currently Wed Jun 25, 2025 2:32 am
 Post subject: too big ?
PostPosted: Thu Apr 27, 2006 2:10 am
Die Die Die!!
just a question easiest to ask you lot.. a Daihatsu Charade.. 1995.. 1.3 engine will it be too big for a roundnose.
PostPosted: Thu Apr 27, 2006 4:00 am
Been a while since I've seen one, but I think it should fit nicely.
I would be taking some photos & measurements before buying a front cut though :)
PostPosted: Thu Apr 27, 2006 8:01 am
I know the 3 cylinder one litre fits neatly , don't know how much the extra cylinder adds to the length though . Go for a scrounge through a wreckers or used car yard with a tape measure , if it's only a slight difference then maybe , if it's a big difference then have another think about it . The 3 cylinder motor is quite a good motor and was available as a turbo twin cam as well , not really to be ignored .
PostPosted: Thu Apr 27, 2006 8:30 am
the 1.3 motor will fit in a round nose i measured one up years ago when i did a N/A 4efe conversion i chose the 4efe over the daihatsu because it was a twin cam
:oops: yes I was young and thought everything had to be a twin cam to be good
57 Morris minor
88 Rover Mini
PostPosted: Thu Apr 27, 2006 9:28 am
The 4efe would be a good conversion. I'm driving my sister's starlet at the moment. It goes great. Would go even better in a mini!
PostPosted: Thu Apr 27, 2006 1:10 pm
Die Die Die!!
hmm ok.. well ill have a good look into this.. :)
