It is currently Fri Jul 04, 2025 12:08 pm
 Post subject: Double row timing chain
PostPosted: Mon Apr 17, 2006 6:32 pm
What are the pros for using a double row timing chain in preference to the single?
PostPosted: Mon Apr 17, 2006 7:11 pm
#1 Duplex don't stretch near as much.
#2 They are twice as hard to break. :wink:
No way I would run a single row chain with a modified cam, & stronger valve springs etc. They wear too fast.
Beware- lots of new chains are crap now, you can bend `em sideways straight from the box.
I bought a UK made, (supposedly) duplex chain for Barney, it was looser new than the old one. :lol:
I've had Chinese chain at work that is better.....!
Best I've found is the German endless `Iwis' duplex, but it's $50 or so.
You do get what you pay for. 8)
PostPosted: Mon Apr 17, 2006 7:14 pm
Thanks Kev
Do you have to do any mods to fit?
I've heard that you have to countersink bottom two bolts behind pulleywheel?
Also do you then need dual chain tensioner?
PostPosted: Mon Apr 17, 2006 7:36 pm
Yes - absolutely you need to coutersink and use countersunk allen key bolts otherwise YOU WILL chew out the chain and the bolts seconds after the engine starts - No Exceptions
No - chain tensioners - I dont and have never had one one - has made no difference on my road car
Ask others
PostPosted: Mon Apr 17, 2006 8:25 pm
You can also use c/sk head Mini brake drum screws, cut to length. Do `em up with an impact screwdriver.. oh and put a dab of Loctite on the threads. :wink:
<edit> I've never used or needed a tensioner with a duplex chain. Only one available right now is the A+ type (which uses a simplex chain).
People do use these on duplex ones, whether it helps I have no idea.
PostPosted: Mon Apr 17, 2006 9:28 pm
I have been advised to run a SIMPLEX timing chain on my 998 race motor, purely as a weight/load saving advantage. Only downside is that the chain would need replacing more often.
PostPosted: Mon Apr 17, 2006 10:21 pm
I'd fit a belt drive kit- lighter, no stretching so no valve timing retard or spark scatter. :wink:
I've run one for 12 years now. No problemo.
I'll change the latest Kevlar belt at 50,000 miles... 8)
PostPosted: Mon Apr 17, 2006 10:26 pm
For the simple fact that I am out of money, the SIMPLEX off my Jap A+998 will be perfect :lol:
But yeah, point taken, belt would be the way to go. Hopefully theyre around the $120 mark :roll:
PostPosted: Mon Apr 17, 2006 10:35 pm
Well yeah, if you haunt eBay- Chong got his S/H but good for $100. :wink:
PostPosted: Tue Apr 18, 2006 2:03 am
What is SIMPLEX? is that just another term for Single rom or something different?
PostPosted: Tue Apr 18, 2006 6:44 am
Simplex = single row
Duplex = double row
Triplex = triple row ......
Sheesh... don't they teach anything in schools these days!! :lol: :P
PostPosted: Tue Apr 18, 2006 6:48 am
Hey, i figured it could have been something new and important since nathan capitalised it! :P
edit: There are triple rows? :shock:
PostPosted: Tue Apr 18, 2006 8:51 am
Ahem I got mine for $150 and it wasn't on Fleebay 8)
PostPosted: Tue Apr 18, 2006 7:11 pm
Yep, there sure are, you won't see them on Mini cam drives though! :lol:
Strictly industrial Heavy Duty (often low speed) drives.
